Recent Changes - Search:
go to the forum
Contents
Site
Help
« aug 2026 · dec 2026 »
    add a calendar item
    PmWiki / Change Log
    %audienceAnonymous
    See the cookbook recent changes page for additional updates and activity by other developers, or join the PmWiki mailing lists to discuss feature development with us.
    Version 2.2.46 (2013-01-07)
    • Add third parameter to fixperms() explicitly setting the permissions.
    • Add $UploadPermAdd and $UploadPermSet variables.
    • Update documentation.
    Version 2.2.45 (2012-12-02)
    • Cleanup some PHP notices (PITS:01304).
    Version 2.2.44 (2012-10-21)
    • Better display of whitespace in page histories.
    • Fix definition for PageTextVariables containing a dash (PITS:00978).
    Version 2.2.43 (2012-09-20)
    • Allow for HTML attribute names to contain dashes, eg. data-transition, data-role etc.
    • Remove warning when previewing Site.EditForm.
    Version 2.2.42 (2012-08-20)
    • Convert the line-endings in the docs/ directory to \r\n compatible with Windows.
    • Modify PHSC() to call htmlspecialchars() with a single-byte encoding argument.
    Version 2.2.41 (2012-08-12)
    • Change $KeepToken to "\034\034" which is compatible with more encodings.
    Version 2.2.40 (2012-07-21)
    • Add PHSC() helper function as a replacement of htmlspecialchars() for PHP 5.4 (PITS:01292).
    Version 2.2.39 (2012-06-25)
    • Fix URL encoding of attachment links.
    Version 2.2.38 (2012-05-21)
    • Fix "Wrong parameter count for utf8_decode" warning, reported by Simon.
    Version 2.2.37 (2012-05-01)
    • Add page filename encoding functions.
    • Better handling of dots in [[#anchor_1.2]] sections (PITS:01285).
    • Expand PageVariables in PageList template defaults (PITS:01282).
    • Add test for iconv() and mb_convert_encoding(), refactor recode().
    Version 2.2.36 (2011-12-28)
    • Add $EnableOldCharset variable and $page["=oldcharset"] entry.
    • Refactor PageStore->recode() to recover Windows-1252 characters.
    • Add exit line to xlpage-iso-8859-2.php (PITS:01275).
    • Fix difference in defining and removing "invisible" PTVs.
    Version 2.2.35 (2011-11-11)
    • Fix critical PHP injection vulnerability (PITS:01271, reported by Egidio Romano).
    • Important change: Disable script loading from XLPage().
    • Move the processing of [[link|+]] inside LinkPage() and delete markup rule from stdmarkup.php.
    • Modify MakeLink() to better handle link titles.
    • Add optional $LinkTitleFunction allowing recipes to customize the link titles.
    • Fix ReadTrail() to better handle links with titles.
    • Add title attributes for the HTML templates in the $LinkPage*Fmt variables.
    • Add upload extensions svg, xcf, ogg, flac, ogv, mp4, webm, odg, epub.
    • Minor optimization for the MarkupExpressions for UTF-8 strings.
    • Minor optimization of the rendering of page history.
    Version 2.2.34 (2011-10-10)
    • Add MarkupExpressions replacements for UTF-8.
    • Reset timestamps of Site(Admin).AuthUser to 1000000000, used in upgrades.php.
    Version 2.2.33 (2011-09-23)
    • Fix locked states for Site and SiteAdmin GroupAttributes (reported by Brijesh Kothari).
    • Fix intermap.txt entries PITS: and Wikipedia: to point to their current locations.
    • Fix refcount.php to produce valid HTML (PITS:01266).
    Version 2.2.32 (2011-09-18)
    • Add required html xmlns attribute to the print skin template.
    • Add PageStore->recode() function.
    • Add $DefaultPageCharset array.
    • Optimize for speed the inline diff for page history when too many lines were added or deleted.
    • Update and convert to UTF-8 the documentation.
    Note: Due to a manipulation error, a version 2.2.31 was created before it was ready for a release.
    Version 2.2.30 (2011-08-13)
    • Fix $Charset definition in iso-8859-*.php files.
    • Add $EnableRangeMatchUTF8, set it to 1 to enable range matches in UTF-8.
    Version 2.2.29 (2011-07-24)
    • Fix Attach links that were broken with the Path fix in 2.2.28.
    • Add $IMapLocalPath array containing InterMap prefixes that should be treated as local.
    Version 2.2.28 (2011-07-24)
    • Fix potential XSS vulnerability in refcount.php (PITS:01262).
    • Fix bug in Path: links (PITS:01260).
    • Fix potential XSS vulnerability in custom SitePreferences (PITS:01263).
    Version 2.2.27 (2011-06-19)
    • Add block WikiStyle %justify% (PITS:01253).
    • Remove unused <vspace> after a redirection (PITS:01255).
    • Add ?nodiff=1 parameter for page history to disable diff rendering and show only restore links.
    Version 2.2.26 (2011-05-21)
    • Fix ReadTrail(), redundant replacing of hashes, already done in MakePageName().
    Version 2.2.25 (2011-03-22)
    Version 2.2.24 (2011-02-15)
    • Add {$$PageTrailDepth} pseudovariable for pagelist templates.
    • Fix PageVar(), add $authpage array for an authenticated page data, removed $EnablePageVarAuth.
    Version 2.2.23 (2011-01-25)
    Version 2.2.22 (2011-01-16)
    Version 2.2.21 (2010-12-14)
    • Fix potential XSS vulnerability, reported by DFaure.
    • Fix invalid HTML for simple table captions, reported by JL.
    • Fix WikiStyles could work not properly if a value was empty like accesskey="".
    Version 2.2.20 (2010-12-14)
    • Fix Pagelist {$$variable} didn't work in template none (PITS:01212).
    • Fix interface access keys in browse mode (PITS:01188).
    • Add PmL10n: intermap prefix for the Localization/ group on pmwiki.org (PITS:01180).
    • Fix AuthUser excluding members didn't work (PITS:01201).
    Version 2.2.19 (2010-11-10)
    Version 2.2.18 (2010-09-04)
    • Fix $SaveAttrPatterns to skip nested conditionals (reported by RandyB).
    • Fix RecentChanges when an edit summary contains the dollar sign (PITS:01217).
    • Fix RDF feed number of elements (PITS:01198).
    Version 2.2.17 (2010-06-20)
    • Add tabindex as a valid form attribute (PITS:01190).
    • Collapse adjacent insertions in DiffRenderSource (PITS:01192).
    • Fix HandleDownload to flush() output before exit (PITS:01199).
    • Fix HandleDownload to respect $EnableIMSCaching (PITS:01191).
    • Add $PostConfig functions and scripts, loaded after stdconfig.php (PITS:01132).
    • Add $AuthUserPat variable for the regexp pattern in AuthUserId() (PITS:01202).
    • Pass $authlist as last parameter to $AuthUserFunctions (PITS:01197).
    • Fix "exists" conditional to work with old link markup.
    Version 2.2.16 (2010-05-10)
    • Allow "exists" conditional to accept wildcards (PITS:01184)
    • Fix GUI button %center% which didn't work correctly.
    • Fix incorrectly parsed quote in PQA(), possible script injection (discovered by Hanno Boeck).
    Version 2.2.15 (2010-03-27)
    • Add (Auth|Edit)Form to auto-translated titles.
    • Fix (:if auth LEVEL:) to respect $HandleAuth (PITS:01164).
    • Skip loading of the second half of draft.php if $action!="edit".
    • Fix bug with (:template none:) introduced in 2.2.14, reported by Holger.
    • Fix HandleDownload() to use binary file-read.
    Version 2.2.14 (2010-02-27)
    • Fix inline styles in WikiTrails (PITS:01121).
    • Add a negation parameter to pagelist first/last templates (PITS:01127).
    • Refactor FPLTemplateFormat(), move repeated code blocks into FPLExpandItemVars().
    • Add $EnableUndefinedTemplateVars allowing to hide or show undefined template/include {$$variables} (PITS:01152).
    • Add "title" attribute to external links (PITS:00657).
    • Add FmtPageTitle() to allow automatic i18n titles for RecentChanges and other technical pages (PITS:01157).
    Version 2.2.13 (2010-02-21)
    • Replace deprecated in PHP 5.3 function split() with explode().
    • Add $WordDiffFunction default to PHPDiff().
    • Use existing border colors as highlighting background.
    • Refactor/optimize DiffRenderSource(), merge with DiffRenderInline().
    • Change default history to show word-level highlighting.
    • Fix bug with $DiffKeepNum which kept less revisions than it should.
    • Fix RetrieveAuthPage() call from HandleDiff().
    Version 2.2.12 (2010-02-17)
    • Allow a custom $DiffHTMLFunction to skip the line rendering if it returns false.
    • Add $EnableDiffInline, simple word-level diffs (PITS:00571).
    Version 2.2.11 (2010-02-14)
    • Break PrintDiff() into customizable functions (PITS:01106).
    • Add anchors to individual diffs (PITS:00796).
    • Remove unused $RecipeInfo definition in markupexpr.php (reported by P.Bowers).
    • Add (:head:) and (:headnr:) table directives (PITS:00535).
    • Fix $GroupPattern and $NamePattern in xlpage-utf-8.php.
    Version 2.2.9, 2.2.10 (2010-01-17)
    • Fix i18n string in PasswdVar(), reported by SteP.
    • Fix sample-config.php with correct information about $EnableWSPre (PITS:01145).
    • Fix range searches for wikis in UTF-8 (reported by Maxim).
    • Fix global variable $StringFolding in scripts/xlpage-utf-8.php.
    • Fix markup for italics in creole.php.
    • Fix previews for PTVs, Pagelist templates and included sections (PITS:01098).
    • Add $DiffKeepNum - number of revisions kept, even if older than $DiffKeepDays.
    • Add Yandex to robots.php.
    • Change default $EnableRelativePageVars to 1 (PITS:01145).
    • Add fifth parameter to SetProperty() : keep existing property.
    • Add $EnablePageTitlePriority (PITS:00266, PITS:00779).
    Version 2.2.8 (2009-12-07)
    • Fix apostrophes in Author field (PITS:01155).
    • Fix Condition "exists" for PHP 5.3 (PITS:01156).
    Version 2.2.7 (2009-11-08)
    • Fix GlobToPCRE() to work with !excl and -excl with PHP 5.3 (PITS:01149).
    • Fix HandleDownload() correctly quote the filenames (PITS:01150).
    • Fix SessionAuth() for PHP 5.3, the $_REQUEST array doesn't contain the $_COOKIE array (PITS:01141).
    • Fix default timezone for PHP 5.3 (PITS:01141).
    Version 2.2.6 (2009-10-04)
    • Escape apostrophes for multiline textarea/hidden form fields.
    • Fix global unset of $MarkupRules in Markup() and DisableMarkup(), reported by D.Faure.
    • Fix call to BuildMarkupRules() in MarkupToHTML(), suggested by Pm.
    • Allow disabling of $PageListFilters and $FPLTemplateFunctions if set to -1 and thus allow replacing a core function with a custom one.
    • Fix DRange() returned timestamps +1min or +1day when it shouldn't (PITS:01125).
    • Add $MarkupWordwrapFunction to allow custom (:markup:) line width for multibyte wikis (PITS:00703).
    • Add $MakeUploadNamePatterns to allow custom filename normalization for uploads.
    • Add a fourth argument to PostRecentChanges() to allow this function to be called with a custom $RecentChangesFmt array.
    • Add $RecentUploadsFmt, to allow logging of new uploads to the RecentChanges pages (PITS:00088).
    • Fix Notify for some installations in safe_mode (PITS:00976).
    • Add $HTMLHeaderFmt['guiedit'] variable in guiedit.php to allow customization (PITS:01146).
    Version 2.2.5 (2009-08-25)
    • Add *.7z as accepted upload extension (PITS:00813).
    • Fix global variable $HandleAttrFmt in HandleAttr (PITS:01126).
    • Allow brackets in input element names (PITS:01131).
    • Fix CSS class applied twice (PITS:01071).
    • Fix Not-Modified headers could prevent caching (PITS:00802).
    • Break FPLTemplate() into configurable sub-parts (PITS:01102).
    • Add (:template none:) section for Pagelist templates.
    • Fix attr-protected page could be deleted with edit permissions (PITS:00238).
    Version 2.2.4 (2009-07-16)
    • Fix bug with page attributes, which somehow didn't make it in the 2.2.3 release.
    • Fix bug with HTML entities in XLPages introduced earlier today in 2.2.3 (reverted, PITS:01114).
    Version 2.2.3 (2009-07-16)
    • Fix action=logout could incorrectly set a session cookie (PITS:01062).
    • Fix page history trim in vardoc.php (PITS:01103).
    • Add $EnableUploadGroupAuth, use group password for downloads (PITS:01104).
    • Fix recursive PTV loops, added $MaxPageTextVars (PITS:00915, PITS:01099).
    • Fix mkdirp() messages for absolute paths (PITS:00396).
    • Fix sample-config.php order for urlapprove.php (PITS:01037).
    • Fix broken signature links on preview.
    • Fix crypt.php (action=crypt) could malfunction for passwords with quotes or apostrophes.
    • Fix @_site_* passwords to work in GroupAttributes (PITS:00836, PITS:00998).
    • Fix possible XSS vulnerabilities, reported by Michael Engelke.
    Version 2.2.2 (2009-06-21)
    • Fix class in pages not on the breadcrumbs trail, reported by Ed W.
    • Fix tabindex and onclick to guiedit buttons.
    • Fix $GroupPrintHeaderFmt in print.php (PITS:01073).
    • Fix global vars in xlpage-utf-8.php (PITS:00980).
    • Fix $txt in LinkPage (reported by Eemeli Aro).
    • Add $EnableNotifySubjectEncode for international wikis (Cookbook:UTF-8).
    • Fix international message in Abort().
    • Fix security bug with AuthUser, reported by Eemeli Aro. See Release notes.
    • Fix $ActionTitleFmt for login and upload, reported by Eemeli Aro.
    Version 2.2.1 (2009-03-28)
    • Fix $FPLTemplateMarkupFunction which somehow didn't get in the 2.2.0 archive.
    • Fix wikitrails to work cross-group (PITS:00407).
    • Add $EnableRedirectQuiet variable (PITS:00919).
    • Fix {$Title} could display global variables (reported by HansB).
    • Fix reloaded form submissions could lose values (reported by DaveG).
    • Fix preview while restoring a version from history (PITS:01081).
    • Fix relative links with international characters (reported by G. Hermanowicz).
    • Add in sample-config.php example call to xlpage-utf-8.php (PITS:01066).
    • Fix guiedit.php to produce valid HTML.
    Version 2.2.0 (2009-01-18)
    • Convert beta series to official release series.
    • Add $FPLTemplateMarkupFunction (PITS:00984, requested by John Rankin).
    Version 2.2.0-beta68 (2008-08-14)
    • Fix E_NOTICE errors reported by Dominique Faure.
    • Enable (:redirect:) directives in pagelists.
    Version 2.2.0-beta67 (2008-07-13)
    • Add {$LastModifiedTime} page variable.
    • Add $EnableSessionPasswords variable to control session password usage.
    • Add $SessionEncode and $SessionDecode variables to specify functions for encoding/decoding sensitive session data.
    • Updated httpauth.php to use SessionAuth instead of poking in session guts directly.
    Version 2.2.0-beta66 (2008-07-04)
    • Add content-type/charset to Abort() output (suggested by Petko).
    • Close minor XSS vulnerability (PITS:01030).
    • Add "nested if" capability.
    • Fix bug in $Transition handling that would enable all transitions if any were set (reported by John Rankin).
    Version 2.2.0-beta65 (2007-11-17)
    • Fix SiteAdmin.AuthList so that it defaults to list=all (reported by Roman).
    • Fix pmwiki skin to include xmlns= attribute in <html> tag (PITS:00989, reported by Mateusz Czaplinski and Petko Yotov).
    Version 2.2.0-beta64 (2007-11-13)
    • Add times to PmWiki date parsing (e.g., 2007-08-09T12:22:04).
    • Suppress warning from ini_set in diag.php (suggested by Petko).
    • Fix handling of -> links in trails (reported by Eemeli Aro).
    • Add .kml and .kmz as valid attachment types.
    • Fix handling of &amp; in markup (PITS:00988, reported by Stirling Westrup).
    • Fix duplication of language markers in $XLLangs (PITS:00987, reported by Stirling Westrup).
    • Correct typo in DRange() call in stdmarkup.php (reported by Stirling Westrup).
    • Turn on error displays when diagnostics are enabled.
    • Default PHP's pcre.backtrack_limit to at least 1000000.
    Version 2.2.0-beta63 (2007-07-31)
    • Added $SkinDirectivesPattern to allow adjustments to available skin directives (requested by Petko).
    • Fix default permissions on Site.AuthUser and Site.AuthList (reported by Scott Connard).
    • Add "monospace" to pmwiki.css default (reported by Joshua Timberman, with assistance from H. Fox)
    • Fix problem with slashes in wildcards to name= and group= parameters (reported by Ian MacGregor).
    Version 2.2.0-beta62 (2007-07-21)
    • Fix bug in trails introduced by beta61 (reported by charlequin).
    Version 2.2.0-beta61 (2007-07-19)
    • Add ability to grab trails by section.
    • Add an "ontrail" condition (from suggestions by charlequin).
    Version 2.2.0-beta59, 2.2.0-beta60 (2007-07-18)
    • Fix problem with upgrade.php on wiki farms (reported by Scott Connard).
    • Fix problem with distributed version of Site.AuthUser (reported by Jon Haupt).
    Version 2.2.0-beta58 (2007-07-17)
    • Significant change: Site.AuthUser, Site.Blocklist, Site.ApprovedUrls, and Site.NotifyList now appear in the SiteAdmin group by default.
    • Abort if ldap: authentication requested and libraries aren't present.
    • Added "upgrades.php" script to handle various migration issues.
    • Current PmWiki version is now held in SiteAdmin.Status .
    • Fix ?action=postupload to follow ?action=upload settings.
    • Improvements to SiteAdmin.AuthList page (suggestions and fixes from Ian MacGregor).
    • Allow leading underscores in attachment names (requested by Christophe David).
    Version 2.2.0-beta57 (2007-06-15)
    • Fix AsSpacedUTF8() to work like AsSpaced() (reported by Petko).
    • Qualify page links that contain parentheses (reported by Petko).
    • Fix bug in (:input default $:var ... :) (reported by Crisses).
    Version 2.2.0-beta56 (2007-06-13)
    • Fix AsSpaced() to not add spaces before leading digit, and treat hyphenated digits as complete numbers.
    • Fix infinite recursion in self-referencing page text variables (PITS:00915).
    • Fix bug introduced in beta55 not handling end anchors correctly (reported by Roman).
    Version 2.2.0-beta55 (2007-06-11)
    • Fix attributes to (:input e_form:) (PITS:00387, re-reported by Crisses).
    • UpdatePage() now calls StopWatch() to record posting.
    • Display stopwatch output as part of redirect.
    • Fix wiki styles bug when $EnableLinkPageRelative is set (reported by Petko).
    • Revise TextSection() code to hopefully avoid pcre limits (reported by Kathryn Andersen, Knut Alboldt).
    • Add wrap=inline and wrap=none options to page list.
    Version 2.2.0-beta53, 2.2.0-beta54 (2007-06-02)
    • Improve error message reporting for markup rules (suggestion by Knut Alboldt).
    • Clean up more E_NOTICE warnings (reported by Ian MacGregor).
    • Add focus= option to (:input:) controls.
    • Added CSS .faqtoc class, to be able to display only the questions coming from the #includefaq page list template.
    • Changed PmWiki.FAQ to use .faqtoc class.
    • Fix bug in TextSection (PITS:00935, reported by Jean-Fabrice).
    • Fix bug in page list caching of trails.
    Version 2.2.0-beta52 (2007-05-26)
    • Add per-PageStore attributes (from a suggestion by Tobias Thelen).
    • Add {$PasswdRead}, {$PasswdEdit}, etc. to display page password settings.
    • Add Site.AuthList to display all password permissions on a site.
    • Reorder $PageListFilters slightly.
    • Add "passwd=" option to page list, to return only those pages that have some sort of password attribute on them.
    • Add line numbers to StopWatchHTML output.
    • Clean up handling of $AuthCascade.
    Version 2.2.0-beta51 (2007-05-23)
    • Add fmt=count to page list (reminder from Hans).
    • Ignore hidden files in skin directories when searching for .tmpl (suggestion by Stephan Becker).
    • Clean up queuing of pages to be updated in .pageindex .
    • Reset $LinkTargets() at beginning of each UpdatePage() sequence.
    Version 2.2.0-beta50 (2007-05-22)
    • Fix HTML cache when drafts are enabled, or other recipes using CondAuth().
    • Prevent page lists with protected pages from HTML cache.
    Version 2.2.0-beta48, 2.2.0-beta49 (2007-05-21)
    • Fix spurious value= attribute in <textarea> tag generated by (:input textarea ... :).
    • Allow either (:input default ...:) or (:input defaults ...:).
    • Fix problem with page text variable handling in (:input defaults:).
    • Allow either (:template default:) or (:template defaults:) in page list templates.
    • Fix a bug handling dates with suffixes (reported by Crisses).
    Version 2.2.0-beta47 (2007-05-20)
    • Fix bug with quote handling in (:include:) options (reported by Hans).
    Version 2.2.0-beta46 (2007-05-19)
    • Moved $PageTextVarPatterns definition from scripts/stdmarkup.php to pmwiki.php.
    • Ignore Markup() rules that have unresolved $when parameters.
    • Fix issue in authuser.php when $auth array isn't set (contributed by Ben Stallings).
    • The (:include:) directive now performs template argument processing on the included text.
    • Optimized (:pagelist:) slightly when sorting on page variables.
    • Refactored (:input ... :) markups.
    • Added HandleDispatch(), which allows action handlers to easily redispatch to other actions (and add messages).
    • Added FmtTemplateVars(), to perform various template-substitutions.
    Version 2.2.0-beta45 (2007-05-02)
    • Update pmwiki's date parsing to use a common routine, recognizing dates within strings and restricting range to 1900-2039.
    • Add additional parameter to "date" conditional.
    • Add if= option to page list (suggested by Crisses).
    • Refactor code to use TextSection() and RetrieveAuthSection() functions.
    • The value= parameter to (:input textarea:) now works properly (including values loaded from $InputValues).
    • The (:input default:) directive now allows loading input control defaults from another page via the source= parameter.
    • Remove automatic call to FmtPageName() in $ROSPatterns. Add $ROEPatterns (from suggestions by JB and others).
    • Fix minor variable bugs in scripts/crypt.php.
    • Remove E_NOTICE errors (reported by Hans).
    • Fix handling of page variables when pagename is empty or not provided.
    • Add $EnableLinkPageRelative configuration option.
    • Clean up handling of arguments to {(ftime ...)}.
    • Remove mailposts.php call in stdconfig.php (reported by Christophe David).
    Version 2.2.0-beta44 (2007-04-16)
    • Fix case conversion of U+027D and U+026B (reported by Petko).
    • Add $FTimeFmt to set default formatting for {(ftime)}.
    • Add %s conversion to {(ftime)} for systems that don't have it by default.
    • Report an error if edit form cannot be read (suggested by Hans).
    • Don't report ?cannot acquire lockfile when simply browsing pages.
    • Add $EnableReadOnly flag to signal when PmWiki is to be run in read-only mode.
    Version 2.2.0-beta43 (2007-04-15)
    • Update drafts code to add $EnablePublishAttr and change button labels when drafts are enabled (PITS:00755).
    • Removed no-longer-needed 'compat1x.php' and 'mailposts.php' from distribution.
    • Added $DraftRecentChangesFmt.
    • Added "markup expressions" {(...)} into the core.
    • Added charset= attribute to saved pages.
    • Update pagelist.php and xlpage-utf-8.php to handle case-insensitive searches.
    • Added some optimizations to phpdiff.php script to produce more useful history information.
    Version 2.2.0-beta42 (2007-03-27)
    • Fix a bug with order=title in pagelists (reported by Anno).
    Version 2.2.0-beta41 (2007-03-26)
    • Added $EnableWSPre option, which allows easy adjustment of the "leading space -> preformatted text" (or "whitespace") rule.
    • Added a new "pre" wikistyle, to designate blocks that are to be treated as preformatted text.
    Version 2.2.0-beta40 (2007-03-24)
    • Fix bug with order=title in pagelists when using $Titlespaced (PITS:00906, reported by Feral).
    • Report state of allow_url_fopen when downloads fail in blocklist.php.
    Version 2.2.0-beta39 (2007-03-23)
    • Allow page variable filters to appear as options in (:template defaults:) (reported by SteP).
    • Updated Site.PageListTemplates to use (:template:) directives.
    • Remove '#wikileft h1' and '#wikileft h5' from pmwiki default stylesheet.
    Version 2.2.0-beta38 (2007-03-22)
    • Strip control characters from $ChangeSummary.
    • Fix problem with count=m..n where m..n is outside the range of available pages (reported by SteP).
    • Allow (:template default ...:) to specify a class= option.
    • Redirect pagename can now include an anchor (PITS:00558)
    Version 2.2.0-beta37 (2007-03-16)
    • Allow an optional space after comma separators in wildcard patterns (reported by Han Baas).
    Version 2.2.0-beta36 (2007-03-16)
    • Allow nested page text variables to work, remove extraneous ENT_NOQUOTES parameter.
    • Add new (:template ...:) directives for pagelist templates.
    • Modify count= option to pagelists to allow for alternate ranges.
    Version 2.2.0-beta35 (2007-03-05)
    Version 2.2.0-beta33, 2.2.0-beta34 (2007-03-01)
    • Refactor wildcard handling into its own GlobToPCRE function.
    • Allow negated wildcards for page variable filters in pagelists (PITS:00878, reported by Jiri)
    • Fix wildcards so that spaces no longer separate patterns (use commas).
    • Fix handling of '&' prior to (:input:) and other directives (reported by Luigi).
    • Adjust position of %define=...% wiki styles to occur after ampersands.
    • Adjust copyright dates on many files.
    • Allow spaces around text variable names in page text variable markups.
    Version 2.2.0-beta32 (2007-02-28)
    • Fix erroneous $EnableCreole item in docs/sample-config.php (reported by Sigurd).
    • Added (:elseif:) and (:else:) markups (PITS:00787).
    • Fix global $Skin variable handling when using SetSkin from within markup.
    • Make sure directives aren't treated like page text variables (reported by Petko).
    • Remove call to ResolvePageName() from authuser.php .
    • Simplify LDAP authentication for Active Directory sites.
    • Cache lowercase/uppercase patterns in AsSpacedUTF8().
    Version 2.2.0-beta31 (2007-02-11)
    Version 2.2.0-beta29, 2.2.0-beta30 (2007-02-09)
    • MakePageName now uses the first matching entry of $PagePathFmt as the home page of groups without a home page.
    • Add AsSpacedUTF8() to handle title spacing in utf-8 (PITS:00875, contributed by Petko, Celok)
    • Fix $RequestedPage when running with utf-8.
    • Add <meta> content-type tag for utf-8.
    • Add an experimental caching system for pagelists.
    • Fix $SuffixPattern and link suffixes for utf-8 (PITS:00881, reported by ppip).
    Version 2.2.0-beta28 (2007-02-03)
    • Update blocklist.php so that all posted fields are checked for block values (PITS:00850).
    Version 2.2.0-beta27 (2007-01-25)
    • Fix markup processing sequence for (:input default:), (:input select:), etc. (problem noted by Marc).
    • Fix default value of order= parameter to MakePageList().
    Version 2.2.0-beta26 (2007-01-23)
    • Fix a bug where pagelist list= option had no effect when reading from trails (from an rss problem noted by Russ Fink).
    Version 2.2.0-beta24, 2.2.0-beta25 (2007-01-22)
    • Add a scripts/creole.php module for Creole markup (http://www.wikicreole.org/).
    • Move WikiWords out of the core defaults -- can be enabled via $EnableWikiWords.
    • Fix handling of WikiWords following & or #, as in &AElig; and #FFFF00 (reported by Moni Kellermann).
    • Adjust FormatTableRow() to support Creole-style tables (using single |'s).
    • Update docs/sample-config.php with new configurations and options.
    • Added code to allow Abort() to refer to additional information on pmwiki.org.
    • Added $EnableSkinDiag, which checks templates for required <!--HTMLHeader--> and <!--HTMLFooter--> directives.
    • Removed deprecated $BasicLayoutVars support from skins.php.
    Version 2.2.0-beta22, 2.2.0-beta23 (2007-01-17)
    • Added $EnableActions, to allow pmwiki.php to be included without generating output (from a suggestion by Wouter Groeneveld).
    • Fix bug in "order=" option to (:pagelist:) (reported by Mike Bishop).
    • Change DisplayStopWatch() function to StopWatchHTML().
    • Allow multiple lines for markup:, wiki:, and page: template directives (reported by Marc)
    Version 2.2.0-beta21 (2007-01-12)
    • Fix <vspace> bug in searchresults output (PITS:00846, reported by M. Czaplinski, marc, and others).
    • Fix numerous E_NOTICE warnings and incorrect constants (PITS:00853, contributed by AndrewFyfe).
    Version 2.2.0-beta20 (2007-01-11)
    • $FeedPageListOpt needs to be declared global in feeds.php.
    • Add "404 Not Found" status code to ?invalid page name aborts (PITS:00854, suggested by Athan).
    • Remove stale entries from $PageExistsCache when a new PageStore is added (reported by Hans).
    Version 2.2.0-beta19 (2006-12-29)
    • Have blocklist check $_POST['text'] only when it is set (from a report by Simon).
    Version 2.2.0-beta18 (2006-12-28)
    • Change $pagename parameter in UpdatePage() to be passed by reference (suggestion by J. Meijer).
    • Fix $EnableRobotsCloakActions so that it works again with page variables.
    • Add "XML Sitemaps" to $RobotPattern.
    • Change $MetaRobots to return "nofollow,noindex" for non-existent pages.
    • Prefer "404 Not Found" to "403 Forbidden" for robots attempting to do invalid actions on non-existent pages.
    • Add rel='nofollow' to "create attachment" links.
    • Added class='inputbox' to select boxes (suggested by Hans).
    • Added .odt, .ods, and .odp file extensions to allowed uploads (suggested by Algis Kabaila, Robin Sheat, and others).
    • Clean up some error warnings (PITS:00801, contributed by psvo).
    • Set $ScriptUrl to 'https:' when accessed via SSL link (suggestions from C. Ridderström, H. Fox, PITS:00410, PITS:00527, PITS:00595).
    • Fix bug in link= and trail= options to (:pagelist:) (reported by C. Ridderström).
    Version 2.2.0-beta17 (2006-12-13)
    • Fix spurious hidden field in (:searchbox:) output (reported by Hans).
    • Fix $CaseConversions array for \xc4\xb1 and \xc5\xbf (reported by Petko Yotov).
    • Refactor (:input:) markup handling.
    • Add (:input select ...:) markup (PITS:00567).
    • Add (:input default ...:) markup -- may change before 2.2.0 release.
    • Add ability to set defaults for radio/checkbox/select controls.
    Version 2.2.0-beta16 (2006-11-10)
    • Fix problem with (:e_preview:) directive when viewing an edit form (reported by Dominique Faure).
    • Fix out-of-memory problem in scripts/compat1x.php when dealing with large pages to be converted (contributed by Donald Gordon).
    • Fix problem of Variable: lines immediately followed by newline (reported by Hans).
    • Fix uninitialized variable errors in FormatTableRow() (reported by Bob Sanders).
    • Fix second argument of MakeBaseName() (provided by Stirling Westrup).
    Version 2.2.0-beta15 (2006-10-16)
    • Fix bug with displaying multi-line (:var:value:) page text variables (reported by Pico).
    • Improve PageStore ls() method slightly, to restrict pagename searches to directories of a given depth (based on an issue reported by Chris Cox).
    • Added $IsBlocked status variable to scripts/blocklist.php.
    • Added $UnapprovedLink array to report unapproved links.
    • Added $TimeISOFmt, $TimeISOZFmt, and $CurrentTimeISO variables.
    • Switched scripts/feeds.php to use $TimeISOZFmt instead of $ISOTimeFmt.
    • Added request= option to (:pagelist:), switched pagelist to default to not use url/form parameters.
    • Fixed bug with array {$$options} in pagelist.
    Version 2.2.0-beta14 (2006-10-06)
    Version 2.2.0-beta13 (2006-10-04)
    • Fix handling of angle brackets (and potential XSS) in pagelists combined with page text variables (noted by Pico).
    Version 2.2.0-beta12 (2006-10-03)
    • Added the UpdatePage() function into the core.
    Version 2.2.0-beta11 (2006-10-03)
    • Added ability to automatically create targets.
    • Added sample code to docs/sample-config.php for automatic generation of Category.* pages.
    • Fixed character escapes in pagelist {$$option} variables.
    Version 2.2.0-beta10 (2006-10-02)
    • Added {$$option} variables to get option values from (:pagelist:) (based on a recipe from Martin Fick).
    • Changed {$PageCount}, {$GroupPageCount}, and {$GroupCount} to be {$$PageCount}, {$$GroupPageCount}, and {$$GroupCount}.
    • Added {$BaseName} page variable and $BaseNamePatterns.
    Version 2.2.0-beta9 (2006-10-01)
    • Fix bug with $EnablePageListProtect (reported by Brent Zupp).
    • Added ability to select based on page variables in (:pagelist:).
    Version 2.2.0-beta8 (2006-09-30)
    • Update scripts/blocklist.php to check only $_POST['text'] instead of entire markup text.
    • Fix bug in pagelist.php that wouldn't return correctly formatted array in certain circumstances (noted by Florian Fischer and JDem).
    Version 2.2.0-beta7 (2006-09-30)
    • Added scripts/blocklist.php to core.
    • Updated handling of $PageTextVarPatterns.
    • Eliminated need for extra flush() steps in notify.php, pagelist.php.
    Version 2.2.0-beta6 (2006-09-27)
    • Fix bug with initialization of $FeedPageListOpt in scripts/feeds.php (reported by Roman).
    • Fix bug with over-eager (:textvar:value:) markup (from a bug reported by Chris Cox).
    Version 2.2.0-beta4, 2.2.0-beta5 (2006-09-27)
    • Fix bug with name= option in pagelist (reported by Ben Wilson).
    • Fix bug with array_merge under PHP 5 (reported by Kathryn Andersen).
    Version 2.2.0-beta3 (2006-09-26)
    • Remove extra <!----> comment at end of table directives (noted by Ben Stallings).
    • Fix directive form of page text variables (reported by Kathryn Andersen).
    • Add first version of new modular pagelist code.
    Version 2.2.0-beta2 (2006-09-25)
    • Add support for {$:var} page text variables, and (:var:...:) markup.
    • Fix default setting of $EnableRelativePageVars in docs/sample-config.php .
    Version 2.2.0-beta1 (2006-09-25)
    • Added {*$var} page variables (always the currently browsed page).
    • Convert link and page variable handling in (:include:) to be relative to the included page.
    • Added $EnableRelativePageVars and $EnableRelativePageLinks variables, as well as transition options.
    • Added basepage= option to (:include:).
    • Updated $GroupHeaderFmt and $GroupFooterFmt to use basepage= option.
    • Adjusted $MakePageNamePatterns to automatically strip any #... or ?... from the end of a pagename input string (solution to a problem reported by J. Meijer).
    Version 2.1.27 (2006-12-11)
    • Backport in bug fix for TableRowFormat (from 2.2.0-beta16).
    • Add support for {*$Variable} syntax (from 2.2.0 page variables).
    Version 2.1.26 (2006-09-11)
    • Fix a bug with variable referencing that caused feeds.php to get a confused PCache (reported by Helge Larsen).
    Version 2.1.25 (2006-09-08)
    • Fixed a bug in authuser.php that would fail if $AuthUser isn't defined (reported by Hans Huijgen).
    • Added <!--XMLHeader--> and <!--XMLFooter--> aliases to <!--HTMLHeader--> and <!--HTMLFooter--> directives in skin templates (suggested by John Rankin).
    • Added $PageExistsCache (suggested by John Rankin).
    Version 2.1.24 (2006-09-06)
    • Fixed a bug in authuser.php that had trouble dealing with non-array entries in $AuthUser (reported by Udo).
    • Can now specify authorization groups using $AuthUser['@group'] entries.
    • Can now specify an Apache .htgroup-formatted file for authorization groups via $AuthUser['htgroup'].
    Versions 2.1.21, 2.1.22, 2.1.23 (2006-09-05, 2006-09-06)
    • Close a potential security hole with $FarmD when register_globals is set "On".
    • Correct a syntax error in feeds.php (noted by Ben Wilson).
    • Fix a bug that prevented PmWiki from reading page files generated by versions prior to 0.5.6 (discovered by Milan Avramovic).
    Version 2.1.20 (2006-09-04)
    • Fixed a bug in (:attachlist:) when passed a wikiword argument (reported by Kathryn Andersen).
    • Changed $HTMLStylesFmt['markup'] to honor config.php setting (reported by Hans).
    Version 2.1.19 (2006-08-30)
    • Corrected a bug in the pageindex code that was causing the .pageindex to not update as quickly as it should.
    • Slightly changed the handling of 'width' and 'height' in wikistyles.php, so that they can be be applied as attributes to <object> and <embed> tags.
    • Updated the Keep() function to recognize closing block tags as being in the 'B' block pool.
    • Fixed a bug with wikistyles and form tags.
    Version 2.1.18 (2006-08-28)
    • Closed a potential cross-site scripting vulnerability in table markups (reported by JB).
    • Added (:input image:) markup (requested by JB).
    • Fixed problem with ?action=print failing to set {$Action} (reported by Bart).
    Version 2.1.17 (2006-08-26)
    • Added some improvements to IMS caching to better handle logout and authorization actions (PITS:00573, reported by floozy and Henrik Bechmann).
    Version 2.1.16 (2006-08-26)
    • Added $SkinLibDirs variable, to select filesystem and url locations where skins may be found (resolves PITS:00708, as reported by Hagan Fox, with additional suggestions from Ben Wilson).
    • Changed <!--HeaderText--> to <!--HTMLHeader--> in skin templates, and added an optional <!--HTMLFooter--> directive (PITS:00767).
    • Adjusted the pmwiki and print skins to use the new directives.
    Version 2.1.15 (2006-08-25)
    • Fixed issue dealing with order of @_site_* passwords (reported by Jean-Fabrice and others).
    • Added $LocalDir variable (requested by John Rankin).
    • Removed an unnecessary setting of $DefaultPage in scripts/pgcust.php (it's now handled by ResolvePageName() ).
    • Added some variables and changes in wikistyles.php to better support wikipublisher (contributed by John Rankin).
    • RetrieveAuthPage (PmWikiAuth) now recognizes a $level of 'ALWAYS' as indicating that access should always be allowed, regardless of current passwords or identities.
    • Added filter specifier for AuthUser LDAP authentication (contributed by Balu).
    Version 2.1.13, 2.1.14 (2006-08-15, 2006-08-16)
    • Updated scripts/authuser.php to allow ldaps://... authentications (contributed by Michael Brenner).
    • Fixed problem with numeric passwords introduced in 2.1.beta20 (reported by Christophe David and Dirk Blaas).
    Version 2.1.12 (2006-08-07)
    • Corrected typo in Site.SideBar file (reported by Judith Zacharie).
    • Suppressed warning message for search on sites without a wikilib.d/ directory.
    • Added capability for nested divs.
    • Use $Transition['nodivnest'] to restore previous non-nesting div/table behavior.
    • Including authuser.php now automatically resolves pagename.
    • Added (:noaction:) directive to turn off actions.
    • Fixed bug in wikistyles prior to image blocks.
    • Added white-space as allowed wikistyle (suggested by C. Ridderström).
    • Allow colons, hyphens, and dots in id= tags.
    Version 2.1.11 (2006-06-09)
    • Fixed generation of empty paragraphs around %define=...% wikistyles (PITS:00753).
    Version 2.1.10 (2006-06-04)
    • Added a <span> around the RecentChanges link in the pmwiki skin (PITS:00750, suggested by Hagan Fox).
    • Changed the $Action variable to $ActionTitle (PITS:00749, reported by Hagan Fox).
    • Changed $FPLTemplatePageFmt to be an array of pages to be searched for page templates, enabled searching of current page and Site.LocalTemplates page.
    • Updated .vspace margin in sidebar for pmwiki skin (PITS:00751, by Hagan Fox).
    Version 2.1.9 (2006-06-02)
    • Fixed a bug with [[~Author]] links (PITS:00530 reported by Klonk, PITS:00611 reported by weijang, PITS:00671 reported by Stirling Westrup, and helpful clues provided by Clayton Curtis).
    Version 2.1.8 (2006-06-01)
    • Added ability to specify notification entries from local/config.php as well as Site.Notify (suggested by Christophe David).
    • Fixed $Transition['vspace'] from 2.1.7.
    Version 2.1.7 (2006-05-31)
    • Adjusted width of edit form for IE browsers (contributed by Roman and H. Fox).
    • Suppress authentication failure error from LDAP (PITS:00739).
    • Fixed problem with invalid page names resulting in redirect loop (PITS:00723, reported by jojoo).
    • Added "Group." and "Group/" page name syntax, resolving PITS:00736 (from a suggestion by Pico).
    • Changed handling of "vspace" paragraphs.
    • Fixed some XSS vulnerabilities in uploads.php and url links (reported by Moritz Naumann, http://moritz-naumann.com).
    • Added notify.php script, allowing finer control of email notifications.
    Version 2.1.6 (2006-05-22)
    • Optimized performance of urlapprove.php.
    • Added (:if auth xyz PageName:) syntax.
    • Corrected XSS bug in trails.php.
    • Slightly improved performance of free links.
    • Restore ability to use hyphens in InterMap links (reported by Henrik Bechmann).
    Version 2.1.4, 2.1.5 (2006-03-29)
    • Fixed problem with pagelist-based feeds (PITS:00709, reported by Jon Haupt).
    • Added {$Action} page variable. (PITS:00696, reported by Sebastian Pipping).
    • Added stripmagic() around variables submitted to authuser.php.
    • Fixed problem with multi-term searches containing special characters (PITS:00713, reported by Leo).
    • Switched (:attachlist:) to use a natural case sort (suggested by H. Fox).
    Version 2.1.3 (2006-03-17)
    • Re-fixed problem with PHP 5.1.1 and lines= option to (:include:) (PITS:00620).
    • Fixed empty LDAP password issue (reported by Thomas Lederer).
    Version 2.1.2 (2006-03-16)
    • Fixed <h1>/<h2> tag mismatches (PITS:00702, reported by Martin Hason).
    • Fixed bug with $AllowPassword and "nopass" (reported by M. Weiner and bram brambring).
    • Improved the speed of RSS and other web feeds when $EnablePageListProtect is not set.
    Version 2.1.1 (2006-03-13)
    • Fixed a bug with multiple authorization groups as a password (PITS:00699, reported by Ari Epstein).
    • Updated the authorization code to be a bit more liberal with password/group settings.
    • Updated PmWiki.FAQ page to be able to grab FAQ items from other pages in the documentation.
    Version 2.1.0 (2006-03-12)
    • Many many documentation updates (special thanks to many authors).
    • Allow trailing underscores in upload names (requested by Hans).
    • Fixed 'ak_print' problem causing accesskey='a' for print (noted by Pico).
    • Added code to make sure each anchor is generated only once per page (for XHTML validity).
    • Added a $BlockPattern variable to recognize block HTML tags.
    • Made an adjustment to Keep() so that it places strings with block HTML into the 'B' pool.
    • Adjusted stdmarkup.php to not produce paragraphs for keep blocks in the 'B' pool.
    • Corrected a variety of i18n phrases.
    • Added class='escaped' to distinguish @@...@@ from [@...@] (from a comment by Hans).
    • Slightly changed styling of .faq divs.
    • Made the edit textarea a couple of rows smaller to better fit on smaller displays (suggested by H. Fox).
    ChangeLog Archive - changes prior to version 2.1.0.
    This page may have a more recent version on pmwiki.org: PmWiki:ChangeLog, and a talk page: PmWiki:ChangeLog-Talk.
    Edit - History - Print - Recent Changes? - Search Page last modified on 2013-01-07 07:41 [UTC-7] - 642 views
