Recent Changes - Search:
go to the forum
Contents
Site
Help
« aug 2026 · dec 2026 »
    add a calendar item
    PmWiki / Upload Variables
    %audienceAnonymous
    See also: Uploads, Uploads admin.
    $EnableUpload
    The upload.php script is automatically included from stdconfig.php if the $EnableUpload variable is true in config.php. Note that one may still need to set an upload password before users can upload (see UploadsAdmin).
    $UploadPermAdd
    This variable sets additional unix permissions applied to the uploaded files, and should be 0 (recommended as of 2013). If uploaded files cannot be downloaded and displayed on the website, for example with the error 403 Forbidden, set this value to 0444 (core setting, default since 2006).
    $UploadPermAdd = 0; # recommended
    $UploadPermSet
    This variable sets unix permissions unconditionally applied to the uploaded files. Danger! Do not use this variable unless you know what you're doing! If you make a mistake, uploaded files may be impossible to edit or delete via the FTP/SSH account (in that case, Cookbook:Attachtable may be used) or to be downloaded and displayed on the website. Note that file permissions may differ on different systems - if you copy or move your PmWiki installation, you may have to change it.
    $UploadDir
    The directory where uploads are to be stored. Defaults to uploads/ in the pmwiki directory, but can be set to any location on the server. This directory must be writable by the webserver process if uploading is to occur.
    $UploadUrlFmt
    The url of the directory given by $UploadDir. By default, $UploadUrlFmt is derived from $PubDirUrl and $UploadDir.
    $IMapLinkFmt['Attach:']
    The format of the upload link displayed when an attachment is present. No default is set.
    $LinkUploadCreateFmt
    The format of the upload link displayed when an attachment not present. Defaults to
          <a class='createlinktext' href='\$LinkUpload'>\$LinkText</a>
    <a class='createlink' href='\$LinkUpload'> Δ</a>");
    $UploadPrefixFmt
    Sets the prefix for uploaded files to allow attachments to be organized other than by groups. Defaults to '/$Group' (uploads are organized per-group), but can be set to other values for sitewide or per-page attachments.
        $UploadPrefixFmt = '/$Group/$Name';    # per-page attachments
        $UploadPrefixFmt = '';                 # sitewide attachments
    It is recommended to have the $UploadPrefixFmt variable defined in config.php, the same for all pages in the wiki, and not in group/page local configuration files. Otherwise you will be unable to link to attachments in other wikigroups.
    $EnableDirectDownload
    When set to 1 (the default), links to attachments bypass PmWiki and come directly from the webserver. Setting $EnableDirectDownload=0; causes requests for attachments to be obtained via ?action=download. This allows PmWiki to protect attachments using a page's read permissions, but also increases the load on the server. Don't forget to protect your directory /uploads/ with a .htaccess file (Order Deny,Allow / Deny from all).
    $EnableUploadGroupAuth
    Set $EnableUploadGroupAuth = 1; to authenticate downloads with the group password. This could be used together with $EnableDirectDownload = 0;.
    $EnableUploadVersions
    When set to 1 (default is 0), uploading a file to a location where a file of the same name already exists causes the old version to be renamed to file.ext,timestamp (instead of being overwritten). timestamp is a Unix-style timestamp.
    $EnableUploadOverwrite
    When set to 1 (the default), determines if overwriting previously uploaded files is allowed.
    $UploadNameChars
    The set of characters allowed in upload names. Defaults to "-\w. ", which means alphanumerics, hyphens, underscores, dots, and spaces can be used in upload names, and everything else will be stripped.
    $UploadNameChars = "-
    w. !"; # allow dash, letters, digits, dots, spaces and exclamations
    w.
    x80-
    xff"; # allow Unicode
    Note: Not all characters can be used in file names, because of various limitations in protocols or operating systems, file systems and server software, or conflict with PmWiki markup:
    • +?:@#%!=/ have special meanings in URL addresses,
    • |\^`[]?:@#%/ may be impossible to save on some systems,
    • <>"|\^`(){}[]#% may conflict with PmWiki markups,
    so it is strongly recommended to only enable those if you know what you're doing.
    $MakeUploadNamePatterns
    An array of regular expression replacements that is used to normalize the filename of an attached file. First, everything but $UploadNameChars will be stripped, then the file extension will be converted to lowercase. Administrators can override these replacements with a custom definition (the full array needs to be defined).
    $UploadDirQuota
    Overall size limit for all uploads.
       $UploadDirQuota = 100*1024;         # limit uploads to 100KiB
       $UploadDirQuota = 1000*1024;        # limit uploads to 1000KiB
       $UploadDirQuota = 1024*1024;        # limit uploads to 1MiB
       $UploadDirQuota = 25*1024*1024;     # limit uploads to 25MiB
       $UploadDirQuota = 2*1024*1024*1024; # limit uploads to 2GiB
    $UploadPrefixQuota
    Overall size limit for one directory containing uploads. This directory is usually uploads/GroupName (one for every WikiGroup), or uploads/Group/PageName (one for every page), depending on the variable $UploadPrefixFmt.
    $UploadMaxSize
    Maximum size for uploading files, 50000 octets (bytes) by default.
    $UploadExtSize
    Maximum size per extension, overriding the default in $UploadMaxSize.
       $UploadExtSize['zip'] = 2*1024*1024; # allow up to 2MiB for zip files
    This page may have a more recent version on pmwiki.org: PmWiki:UploadVariables, and a talk page: PmWiki:UploadVariables-Talk.
    Edit - History - Print - Recent Changes? - Search Page last modified on 2013-01-07 08:21 [UTC-7] - 906 views
