Recent Changes - Search:
go to the forum
Contents
Site
Help
« aug 2026 · dec 2026 »
    add a calendar item
    PmWiki / Available Actions
    %audienceAnonymous
    Page actions are applied to wiki pages, as a query string appended to the URL. Security can be applied to all default actions, and script actions with one exception, but not diag actions, through the use of passwords.
    Also documented are all other URL queries.
    PmWiki Actions
    See also site page actions.
    ?action=attr
    displays dialog for setting/changing password of the specified page or group of pages, see passwords, see also $EnablePostAttrClearSession if you do not want to have the session cleared after validating change General use of passwords and login
    ?action=browse
    display the specified page (default action if no ?action= is present)
    ?action=crypt
    displays a form for generating hashed passwords out of clear text for usage in your config.php
    ?action=diff
    show a change history of the specified page, see page history History of previous edits to a page
    ?action=download&upname=file.ext
    retrieve the page's attachment named file.ext, see $EnableDirectDownload
    ?action=edit
    edit the specified page, see basic editing PmWiki's basic edit syntax
    ?action=login
    prompt visitor for username/password, by default using Site.AuthForm
    ?action=logout
    remove author, password, and login information
    ?action=print
    display the specified page using the skin specified by $ActionSkin['print']
    ?action=refcount
    bring up the reference count form, which allows the user to generate a list of links (all, missing, existing or orphaned) in or from specified groups. See Ref Count Link references counts on pages . Part of the core distribution but must be enabled by the administrator.
    ?action=search
    displays searchbox on current page, see search Targeting and customising search results
    ?action=search&q=searchterm
    performs search with searchterm and displays results on current page
    ?action=search&q=link=pagename
    performs backlinks search with ''pagename' and displays results on current page
    ?action=source
    show page source
    ?action=atom
    ?action=rdf
    ?action=rss
    ?action=dc
    If web feeds are enabled, returns a syndication feed based on the contents of the page or other options provided by the url, see web feeds Web feed notification of changes
    ?action=upload
    display a form to upload an attachment for the current group, see uploads
    Query string parameters
    ?from=page name
    use when a page is redirected
    ?n=page name
    display page
    ?setprefs=SomeGroup.CustomPreferences
    sets cookie to custom preferences page. See site preferences Customisable browser setting preferences: Access keys, edit form
    Actions enabled by $EnableDiag
    The following actions are available only if you set $EnableDiag = 1; in your configuration file. They can be used for debugging and should not be set in a production environment.
    ?action=ruleset
    displays a list of all markups in 3 columns:
    • column 1 = markup-name (1. parameter of markup() )
    • column 2 = when will rule apply (2. parameter of markup() )
    • column 3 = PmWiki's internal sort key (derived from #2)
    (see Custom Markup Using the Markup() function for custom wiki syntax ).
    To see more than what ?action=ruleset gives you, apply the Cookbook:MarkupRulesetDebugging recipe: it can also show the pattern and the replacement strings.
    • doesn't make use of PmWiki's authorization mechanisms.
    ?action=phpinfo
    displays the output of phpinfo() and exits. no page will be processed
    ?action=diag
    displays a dump of all global vars and exits. no page will be processed
    Actions enabled by PmWiki Scripts
    ?action=analyze
    see Site Analyzer and Analyze Results
    ?action=approvesites
    see Url approvals Require approval of Url links
    Actions enabled by Cookbook recipes
    (more information about Custom Actions)
    ?action=admin
    see Cookbook:UserAuth2
    ?action=backup
    see Cookbook:BackupPages
    ?action=clearsky
    see Cookbook:SearchCloud
    ?action=comment
    see Cookbook:CommentBox
    ?action=comments
    see Cookbook:Comments
    ?action=comment-rss
    see Cookbook:CommentDb
    ?action=convert
    see Cookbook:ROEPatterns
    ?action=converttable
    Cookbook:ConvertTable
    ?action=copy
    see Cookbook:MovePage
    ?action=csv
    see CSVAction?
    ?action=downloaddeleted
    ?action=delattach
    ?action=delattach
    ?action=deldelattach
    ?action=fileinfo
    ?action=thumbnail
    ?action=undelattach
    Cookbook:Attachtable
    ?action=delete
    see Cookbook:DeleteAction
    ?action=discuss
    see Cookbook:DiscussionTab
    ?action=downloadman
    see Cookbook:DownloadManager
    ?action=expirediff
    see Cookbook:ExpireDiff
    ?action=import
    see Cookbook:ImportText
    ?action=move
    ?action=PageUrl
    see Cookbook:CommentBoxPlus
    ?action=pageindex
    see Cookbook:ListCategories
    ?action=pdf
    see Cookbook:GeneratePDF or Cookbook:PmWiki2PDF
    ?action=postupload2
    see Cookbook:UploadForm
    ?action=publish
    see Cookbook:PublishPDF
    ?action=purgeqns
    see Cookbook:ASCIIMath
    ?action=pwchange
    ?action=imgtpl
    (the imgtpl action is called automatically and should not be called by a link in a wiki page)
    ?action=createthumb
    (the createthumb action is called automatically and should not be called by a link in a wiki page)
    ?action=mini
    (this action is called automatically and should not be called by a link in a wiki page)
    ?action=purgethumbs
    see Cookbook:ThumbList
    see Cookbook:Mini
    ?action=recipecheck
    see Cookbook:RecipeCheck
    ?action=regen
    see Cookbook:PageRegenerate
    ?action=rename
    ?action=links
    see Cookbook:RenamePage
    ?action=share
    ?action=unshare
    see Cookbook:SharedPages
    ?action=sitemapaddgroups
    ?action=sitemapupdate
    see Cookbook:Sitemapper
    ?action=totalcounter
    see Cookbook:TotalCounter
    ?action=trash
    ?action=untrash
    see Cookbook:Trash
    ?action=webadmin
    see Cookbook:WebAdmin
    ?action=zap
    see Cookbook:ZAP
    Query string parameters enabled by Cookbook recipes
    ?color=colorscheme
    :?setcolor=colorscheme
    ?skintheme=theme
    ?setskintheme=theme
    see Cookbook:ChoiceColorChanger {Cookbook/ChoiceColorChanger $:Summary}
    ?skin=skinname
    ?setskin=skinname
    see SkinChange
    Custom actions
    This page may have a more recent version on pmwiki.org: PmWiki:AvailableActions, and a talk page: PmWiki:AvailableActions-Talk.
    Edit - History - Print - Recent Changes? - Search Page last modified on 2012-12-02 15:02 [UTC-7] - 749 views
