Recent Changes - Search:
go to the forum
Contents
Site
Help
« aug 2026 · dec 2026 »
    add a calendar item
    PmWiki / Wiki Styles
    authors (basic, advanced)
    WikiStyle basics
    WikiStyles allow authors to modify the color and other styling attributes of the contents of a page. A WikiStyle is written using percent-signs, as in %red% or %bgcolor=lightblue%.
    WikiStyle attributes
    The style attributes recognized within a WikiStyle specification are:
    ------------ CSS ------------- --HTML--
     bgcolor
     background-color
     border1
     color
     background-color
     border
     display
     float
     font-size
     font-family
     font-weight
     font-style
     height*
     list-style
     margin1
     padding1
     text-align
     text-decoration
     white-space
     width*
     accesskey
     align
     class
     hspace
     id
     target
     rel
     vspace
     value
     Special: define, apply
    The attributes in the first two columns correspond to the cascading style sheet (CSS) properties of the same name. The attributes in the last column apply only to specific items:
    • class= and id= assign a CSS class or identifier to an HTML element
    • target=name opens links that follow in a browser window called "name"
    • rel=name in a link identifies the relationship of a target page
    • accesskey=x uses 'x' as a shortcut key for the link that follows
    • value=9 sets the number of the current ordered list item
      • The width and height attributes have asterisks because they are handled specially for <img .../> tags. If used by themselves (i.e., without anything providing an "apply=" parameter to the WikiStyle), then they set the 'width=' and 'height=' attributes of any <img ... /> tags that follow. Otherwise, they set the 'width:' and 'height:' properties of the element being styled.
      1. margin, padding, and border can be suffixed by -left, -right, -top, and -bottom
    WikiStyles versus CSS styles
    WikiStyles, as written in the wiki page, are not exactly CSS styles or CSS classes. WikiStyles allow authors to use both pre-defined by the administrator CSS classes, and to define new combinations of styles, without any need to edit/update local CSS files on the server.
    Note that PmWiki allows advanced authors to use of class= and style= in tables and division blocks, but these are raw HTML attributes, and not WikiStyles, knowledge of CSS is required to use them.
    Text color and font
    The most basic use of WikiStyles is to change text attributes such as color, background color, and font. PmWiki defines several WikiStyles for changing the text color to %black%, %white%, %red%, %yellow%, %blue%, %gray%, %silver%, %maroon%, %green%, %navy%, and %purple%.
    The basket contains %red% apples, %blue%
    blueberries, %purple% eggplant, %green%
    limes, %% and more.
    The basket contains apples, blueberries, eggplant, limes, and more.
    For colors other than the predefined colors, use the %color=...% WikiStyle. (Note: RGB colors (#rrggbb) should always be specified with lowercase letters to avoid WikiWord conflicts.)
    I'd like to have some %color=#ff7f00%
    tangerines%%,  too!
    I'd like to have some tangerines, too!
    To change the background color, use %bgcolor=...% as a WikiStyle:
    This sentence contains %bgcolor=green
    yellow% yellow text on a green
    background.
    This sentence contains yellow text on a green background.
    See WikiStyle Colors for more color help.
    Text justification
    WikiStyles are used to control the text justification
    %center% This text is centered.
    %right% Right justified.
    Right justified.
    and to create floating text:
    %rfloat% This text floats to the right
    %rframe% floats to the right with a
    frame
    Lorem ipsum dolor sit amet, consectetuer
    sadipscing elitr
    floats to the right with a frame
    Lorem ipsum dolor sit amet, consectetuer sadipscing elitr
    Scope
    WikiStyles can also specify a scope; with no scope, the style is applied to any text that follows up to the next WikiStyle specification or the end of the paragraph, whichever comes first. The apply= attribute and its shortcuts allow to change the scope as follows:
    apply attributeshortcutstyle applies to...
    %apply=img ...%-all images that follow until another style applied
    %apply=p ...%%p ...%the current paragraph
    %apply=pre ...%-the current preformatted text
    %apply=list ...%%list ...%the current list
    %apply=item ...%%item ...%the current list item
    %apply=div ...%-the current div
    %apply=block ...%%block ...%to the current block, whether it's a paragraph, list, list item, heading, or division.
    Thus, %p color=blue% is the same as %apply=p color=blue%, and %list ROMAN% is the same as %apply=list list-style=upper-roman%.
    Some predefined style shortcuts also make use of apply, thus %right% is a shortcut for %text-align=right apply=block%.
    Example: Apply a style to a paragraph:
    %p bgcolor=#ffeeee% The WikiStyle specification at the beginning of this
    line applies to the entire paragraph, even if there are %blue% other
    WikiStyle specifications %% in the middle of the paragraph.
    The WikiStyle specification at the beginning of this line applies to the entire paragraph, even if there are other WikiStyle specifications in the middle of the paragraph.
    Caveat: An applied WikiStyle will only take effect if it's on the line that starts the thing it's supposed to modify. In other words, a WikiStyle in the third markup line of a paragraph can't change the attributes of the paragraph:
    after the first line of the paragraph,
    we try to %apply=p color=blue% change
    color.
    This does't work because the style comes
    after the first line of the paragraph.
    after the first line of the paragraph, we try to change color. This does't work because the style comes after the first line of the paragraph.
    However, this %apply=p color=red%
    paragraph
    ''will'' be in red because its block
    style does
    occur in the first line of its text.
    However, this paragraph will be in red because its block style does occur in the first line of its text.
    * Here's a list item
    * %list red% Oops, too late to affect
    the list!
    • Here's a list item
    • Oops, too late to affect the list!
    Larger blocks
    The >>WikiStyle<< block can be used to apply a WikiStyle to a large block of items. The style is applied until the next >><< is encountered.
    >>blue font-style:italic
    bgcolor=#ffffcc<<
    Everything after the above line is
    styled with blue italic text,
    This includes
        preformatted %red%text%%
    * lists
    -> indented items
    Everything after the above line is styled with blue italic text,
    This includes
        preformatted text
    • lists
    indented items
    Note, the (:div style="..." class="...":) directive does not work the same way as >>WikiStyke<<, it can only contain the regular HTML style and class attributes.
    HTML "class" and "style" attributes for tables and divisions
    WikiStyles are only the commands between %...% percent signs.
    Tables, table directives and (:div:) division blocks allow advanced authors to incorporate the HTML/CSS attributes class= and style=. Note that these attributes are not WikiStyles, knowledge of CSS is required to use them.
    (:table style="font-style:italic;
    color:green; border:1px solid blue;
    background-color:#ffffcc":)
    (:cellnr:)
    styled with green italic text,
    This includes
        preformatted text
    * lists
    -> indented items
    (:tableend:)
    Everything after the above line is styled with green italic text,
    This includes
        preformatted text
    • lists
    indented items
    Note, the (:div style="..." class="...":) directive does not work the same way as >>style<<, as mentioned above, it can only contain the HTML style and class attributes.
    Custom style shortcuts
    The define= attribute can be used to assign a shorthand name to any WikiStyle specification. This shorthand name can then be reused in later WikiStyle specifications.
    %define=box block bgcolor=#ddddff
    border="2px dotted blue"%
    %box% [@some sort of text@]
    %box font-weight=bold color=green%
    some sort of text
    some sort of text
    Tip: It's often a good idea to put common style definitions into Group Header pages so that they can be shared among multiple pages in a group. Or, the wiki administrator can predefine styles site-wide as a local customization (see Custom WikiStyles).
    Tip: Use custom style definitions to associate meanings with text instead of just colors. For example, if warnings are to be displayed as green text, set %define=warn green% and then use %warn% instead of %green% in the document. Then, if you later decide that warnings should be styled differently, it's much easier to change the (one) definition than many occurrences of %green% in the text.
    Tip: Any undefined WikiStyle is automatically treated as a request for a class, thus %pre% is the same as saying %class=pre%.
    Predefined style shortcuts
    PmWiki defines a number of style shortcuts.
    • Text colors: black, white, red, yellow, blue, gray, silver, maroon, green, navy, purple (shortcut for %color=...%)
    • Justification: %center% and %right%
    • Images and boxes
      • Floating left or right: %rfloat% and %lfloat%
      • Framed items: %frame%, %rframe%, and %lframe%
      • Thumbnail sizing: %thumb%
    • Open link in new window: %newwin% (shortcut for %target=_blank%)
    • Comments: %comment% (shortcut for %display=none%)
    • Ordered lists: %decimal%, %roman%, %ROMAN%, %alpha%, %ALPHA% (see also Cookbook:OutlineLists)
    Enabling Styles
    Styles not listed above can be enabled by a PmWiki Administrator by modifying the local/config.php file. For instance to enable the "line-height" style attribute add the line
    $WikiStyleCSS[] = 'line-height';
    to the local/config.php file.
    Defining scope for other HTML elements
    You can add additional HTML elements to $WikiStyleApply to apply WikiStyles to other HTML elements. For example to allow styling on table rows, or anchor tags.
    To apply styling to anchor tags, place in config.php:
    $WikiStyleApply['link'] = 'a';
    Then, you can apply a class or style to an anchor link:
    %apply=link red%[[PmWiki.WikiStyles |
    test link]]
    test link
    Or, to apply an ID attribute to a table row TR, place in config.php:
    $WikiStyleApply['row'] = 'tr';
    Then, in an advanced table, you can have:
    (:cellnr:) %apply=row id=myid bgcolor=pink% cell content
    And also in a simple table:
    || border=1
    || %apply=row id=myrowid% 1 || 2 || 3 || 4 ||
    Note, the %apply=row...% WikiStyle should be on the same line as (:cellnr:).
    Examples
    WikiStyle Examples contains a number of examples of ways to use WikiStyles in pages.
    Known Issues
    • Percents in style definitions (like: %block width=50% %) require the use of "pct" instead of "%". PmWiki will convert the "pct" into "%" so that it becomes valid CSS.
    • If you specify multiple values for an attribute, like border="2px solid blue" make sure you place the values in quotes.
    • Be sure to use lowercase letters for red-green-blue hex colors, %color=#aa3333% will work, %color=#AA3333% may not.
    See Also
    This page may have a more recent version on pmwiki.org: PmWiki:WikiStyles, and a talk page: PmWiki:WikiStyles-Talk.
    Edit - History - Print - Recent Changes? - Search Page last modified on 2012-09-19 05:17 [UTC-7] - 848 views
