Recent Changes - Search:
go to the forum
Contents
Site
Help
« aug 2026 · dec 2026 »
    add a calendar item
    PmWiki / Custom Wiki Styles
    administrators (intermediate)
    This page describes the predefined Wiki Styles and how a Wiki Administrator can define additional Wiki Styles as a local customization for all pages (in local/config.php) or specific groups (in local/$Group.php).
    All predefined Wiki Styles are setup in the global array $WikiStyle. To define your own Wiki Styles, add the setting of the correspondent WikiStyle within the array.
    Predefined Wiki Styles
    The following array-values are set by scripts/wikistyles.php using the SDV()-function (so you can overwrite them by setting them prior in config.php or farmconfig.php):
    markup:definition:
    text colors:
    (equivalent to %define=xxxx color=xxxx%)
    black$WikiStyle['black']['color'] = 'black';
    white$WikiStyle['white']['color'] = 'white';
    red$WikiStyle['red']['color'] = 'red';
    yellow$WikiStyle['yellow']['color'] = 'yellow';
    blue$WikiStyle['blue']['color'] = 'blue';
    gray$WikiStyle['gray']['color'] = 'gray';
    silver$WikiStyle['silver']['color'] = 'silver';
    maroon$WikiStyle['maroon']['color'] = 'maroon';
    green$WikiStyle['green']['color'] = 'green';
    navy$WikiStyle['navy']['color'] = 'navy';
    purple$WikiStyle['purple']['color'] = 'purple';
    list-styles:
    decimal$WikiStyle['decimal']['apply'] = 'list';
    $WikiStyle['decimal']['list-style'] = 'decimal';
    roman$WikiStyle['roman']['apply'] = 'list';
    $WikiStyle['roman']['list-style'] = 'lower-roman';
    ROMAN$WikiStyle['ROMAN']['apply'] = 'list';
    $WikiStyle['ROMAN']['list-style'] = 'upper-roman';
    alpha$WikiStyle['alpha']['apply'] = 'list';
    $WikiStyle['alpha']['list-style'] = 'lower-alpha';
    ALPHA$WikiStyle['ALPHA']['apply'] = 'list';
    $WikiStyle['ALPHA']['list-style'] = 'upper-alpha';
    special:
    open links in a new browser-window:
    newwin$WikiStyle['newwin']['target'] = '_blank';
    Turns markup into a comment via display:none CSS
    comment$WikiStyle['comment']['display'] = 'none';
    wiki styles
    frameborder:1px solid #cccccc; padding:4px; background-color:#f9f9f9;
    lfloatfloat:left; margin-right:0.5em;
    rfloatfloat:right; margin-left:0.5em;
    thumb
    lframeframe lfloat
    rframeframe rfloat
    cframe
    preblock white-space:pre
    sideheadblock class:sidehead
    Author-Defined Wiki Styles
    1. The first index of the array defines the style name (e.g. mynewstyle, projectentry etc)
    2. the second index defines the attribute name (e.g. color, background-color, etc.)
    3. the value set defines the attribute value (e.g. red, bold, #00ffcc, etc.)
    Sample: If you want to define a (site-wide) style the same as the page style
    %define=projectentry color:red%
    use
    $WikiStyle['projectentry']['color'] = 'red';
    The $WikiStyle['projectentry']['apply'] variable may be defined if the wikistyle concerns a particular tag. It may be 'item' (for li|dt), 'list' (for ul|ol|dl), 'div', 'pre', 'img', 'p' or the combining 'block' (for p|div|ul|ol|dl|li|dt|pre|h[1-6]). Example:
     $WikiStyle['top']['apply'] = 'item';
     $WikiStyle['top']['class'] = 'top';
    then a markup
     * %top% An important list-item
    will output
     <li class="top">An important list-item</li>
    Printer-Friendly Styles
    If your custom-styles (in local/config.php) are getting very colorful it might be useful to disable them in print-view. This can be done easily by putting them into a condition.
    if($action!="print") {
      // your custom-styles
    Notes
    To be done:
    Questions:
    I tried this but background didn't work, thou border and float worked? /Vincent 2008-04-08
    $WikiStyle['vMenu']['background']='#ffffcc' ;
    $WikiStyle['vMenu']['float']='left' ;
    $WikiStyle['vMenu']['border']='1px dotted red' ;
    Try using $WikiStyle['vMenu']['background-color']='#ffffcc'; -- unlike background, background-color is defined in the $WikiStyleCSS array, which is checked for valid properties.
    Q: How would i set an image to the left of a paragraph in a WikiStyle? I'd like to provide an icon for paragraphs that are notes, important, warnings, etc.
    This page may have a more recent version on pmwiki.org: PmWiki:CustomWikiStyles, and a talk page: PmWiki:CustomWikiStyles-Talk.
    Edit - History - Print - Recent Changes? - Search Page last modified on 2012-03-18 20:05 [UTC-7] - 693 views
