PmWiki / Wiki Word
%audienceAnonymous
A WikiWord is a set of two or more words run together, where the first letter of each word is capitalized. This syntax is also sometimes referred to as "mixed case" or "camel case". Other descriptions of WikiWords are available from Wiki:WikiWord and Wikipedia:WikiWord. Usage as page titles
WikiWords are used as page titles in a wiki-based system. Usage as links
In some wikis (depending on the configuration of PmWiki), a valid link can be created by writing it as WikiWord. In such PmWiki installations, WikiWords surrounded by [=...=] or preceded by a backquote (`) are not turned into links:
See Links for information about PmWiki's rules for forming links and forming page titles. Enabling WikiWord links
WikiWord links are disabled by default since Pmwiki version 2.1 beta2. To enable WikiWord links you need to set in config.php See also WikiWord links to non-existent pages without decoration
If you want to display links to non-existent pages without decoration, place the following lines in pub/css/local.css: span.wikiword a.createlink { display:none; }
span.wikiword a.createlinktext { border-bottom:none; text-decoration:none; color:inherit; }
Finding WikiWord links
If you upgraded from an earlier version and want to convert WikiWord links to standard links, the following will help to find those WikiWord links easier by highlighting them. Set in config.php: $HTMLStylesFmt['wikiword'] = "span.wikiword { background:yellow; }";
Disabling certain WikiWords links
The variable This page may have a more recent version on pmwiki.org: PmWiki:WikiWord, and a talk page: PmWiki:WikiWord-Talk. |
