Recent Changes - Search:
go to the forum
Contents
Site
Help
« aug 2026 · dec 2026 »
    add a calendar item
    PmWiki / Pagelist Variables
    %audienceAnonymous
    $EnablePageListProtect
    When set to 1 (which is the default), causes (:pagelist:) and (:searchresults:) to exclude listing any pages for which the browser does not currently have read authorization. Setting this to zero means that read-protected pages can appear in a listing, but can also speed up searches considerably (because page permissions do not need to be checked).
    $SearchPatterns
    An array of page name patterns to be required or excluded from search and pagelist results. In order to be included in a search listing or page listing, a page's name must not match any pattern that is delimited by exclamation points (!) and must match all other patterns. See Cookbook:SearchPatterns.
    # Limit all searches to Main group
    $SearchPatterns['default'][] = '/^Main\\./';
    # Exclude the Main group from search results
    $SearchPatterns['default'][] = '!^Main\\.!';
    # Exclude RecentChanges pages from search results
    $SearchPatterns['default'][] = '!\\.(All)?RecentChanges$!';
    # Prevent a page from listing itself in (:pagelist:) or (:searchresults:)
    $SearchPatterns['default'][] = FmtPageName('!^$FullName$!', $pagename);
    $SearchBoxOpt
    For example $SearchBoxOpt ['target'] = '$DefaultGroup.Search';
    $EnablePageIndex
    When set to 1, causes PmWiki to maintain a "link and word index" in $PageIndexFile which significantly speeds up categories, backlinks, and searches.
    $PageIndexFile
    The location of the "page index" file for (:pagelist:), defaults to $WorkDir/.pageindex.
    $PageListCacheDir
    The name of a writable directory where PmWiki can cache results of (:pagelist:) directives to speed up subsequent displays of the same list. Default is empty, which disables the pagelist cache.
    # Enable pagelist caching in work.d/
    $PageListCacheDir = 'work.d/';
    $PageSearchForm
    The page to be used to format search results for ?action=search (unless the current page has a "searchresults" directive in it). This variable can be an array, in which case the first page found from the array is used.
    # Use Search page in current group if it exists, otherwise use Site.Search
    $PageSearchForm = array('$Group.Search', '[=$[$SiteGroup/Search]=]');
    $FPLTemplatePageFmt
    The pages to be searched for a pagelist template specified by a fmt=#xyz parameter. Defaults to searching the current page, Site.LocalTemplates? and Site.PageListTemplates.
    # PMWiki default setup
    global $FPLTemplatePageFmt;
    $FPLTemplatePageFmt = array(
        '{$FullName}',
        '{$SiteGroup}.LocalTemplates',
        '{$SiteGroup}.PageListTemplates');
    It can be customized to look in other pages.
    # Search a Group.Templates page as well as the Site templates
        '{$Group}.Templates',
    Or declare defaults for the template array:
    SDV($FPLTemplatePageFmt, array('{$FullName}',
        '{$SiteGroup}.LocalTemplates', '{$SiteGroup}.PageListTemplates')
    $EnableUndefinedTemplateVars
    This variable controls how undefined {$$Variable} is processed in includes and PageList templates. If set to 0 (default), undefined {$$Variable}s are removed from the included section or template. If set to 1, undefined {$$Variable}s are displayed as is, with {$$...}. Note that PmWiki versions 2.2.13 and earlier kept unset include/template variables.
    $EnableUndefinedTemplateVars = 0; # Delete unset raw template variables
    $EnableUndefinedTemplateVars = 1; # Keep and print unset raw template variables
    This page may have a more recent version on pmwiki.org: PmWiki:PagelistVariables, and a talk page: PmWiki:PagelistVariables-Talk.
    Edit - History - Print - Recent Changes? - Search Page last modified on 2011-09-10 12:08 [UTC-7] - 898 views
