Recent Changes - Search:
go to the forum
Contents
Site
Help
« aug 2026 · dec 2026 »
    add a calendar item
    PmWiki / Edit Variables
    %audienceAnonymous
    To set many of the variables below specify them in config.php.
    $AutoCreate
    Used in conjunction with the AutoCreateTargets edit function, this array records any sets of pages which should be created automatically if they don't exist. The syntax is
    $AutoCreate[REGEXP] = PAGE_PARAMETERS;
    where REGEXP is a regular expression which will identify the pages to be autocreated, and PAGE_PARAMETERS is an array of attributes for the page to be created. For example,
    $AutoCreate['/^Category\\./'] = array('ctime' => $Now);
    will create a blank page with a current creation time for any missing Category page.
    $DefaultPageTextFmt
    The text that should be displayed when browsing non-existent pages. As default PmWiki uses the contents of Site.PageNotFound
    $DefaultPageTextFmt = '(:include $[{$SiteGroup}.PageNotFound]:)';
    $DeleteKeyPattern
    The pattern used to determine if a page should be deleted. The default is to remove pages that contain only the single word "delete" (and optional spaces).
    # change delete word to "remove"
    $DeleteKeyPattern = "^
    s*remove
    s*$";
    # delete any page with no visible text, i.e., empty
    s*$";
    $DiffKeepDays
    The $DiffKeepDays variable sets the minimum length of time that a page's revision history is kept. By default it is set to 3650 days, or a little less than ten years. You can change this value in a customization file to be something smaller, e.g.:
    $DiffKeepDays = 30; # keep revisions at least 30 days
    Note that a specific page revision isn't removed from the page until the first edit after the time specified by $DiffKeepDays has elapsed. Thus, it's still possible for some pages to have revisions older than $DiffKeepDays -- such revisions will be removed the next time those pages are edited.
    $DiffKeepNum
    This variable contains the minimum number of changes to be kept in the page history, even if some of them are older than the limit defined by $DiffKeepDays. It prevents lost history of pages that are older, but have few changes.
    $DiffKeepNum = 50; # keep at least 50 revisions (default is 20)
    $DraftSuffix
    The suffix to use for draft versions of pages (default "-Draft").
    $EditFunctions
    This array contains the sequence of functions that are called when a page is edited. It can be customized to provide additional functions to be called as part of the editing process. The standard setting is:
    $EditFunctions = array('EditTemplate', 'RestorePage', 'ReplaceOnSave',
      'SaveAttributes', 'PostPage', 'PostRecentChanges', 'AutoCreateTargets', 'PreviewPage');
    $EditRedirectFmt
    The page to which an author is sent after pressing "Save" or "Cancel" from an edit form. Defaults to "$FullName", which sends the author to the page just edited, but can be changed to specify another page.
    # redirect to Main.HomePage
    $EditRedirectFmt = 'Main.HomePage';
    # redirect to HomePage of current group
    $EditRedirectFmt = '{$Group}.HomePage';
    $EditTemplatesFmt
    Name of the page (or an array of names) to be used as the default text for any newly created pages.
    # Use 'Main.NewPageTemplate' as default text of all new pages
    $EditTemplatesFmt = 'Main.NewPageTemplate';
    # Use 'Template' in the current group for new pages
    $EditTemplatesFmt = '$Group.Template';
    # Use 'Template' in the current group if it exists, otherwise
    # use 'Main.NewPageTemplate'
    $EditTemplatesFmt = array('$Group.Template', 'Main.NewPageTemplate');
    See Cookbook:EditTemplates for more information.
    $EnableDrafts
    When set to '1', enables the "Save draft" button and built-in handling of "draft" versions of pages, where:
    1. initial "Save draft" of an existing page ("PageName") saves changes to a new name ("PageName-Draft")
    2. subsequent attempts to edit PageName causes PageName-Draft to be edited
    3. subsequent selections of "Save draft" cause PageName-Draft to be saved
    4. pressing "Publish" causes PageName-Draft to be posted to PageName, and deleted.
    # turn on draft edits
    A related variable, $EnablePublishAttr, adds a new "publish" authorization level to distinguish editing of drafts from publishing them.
    $EnableGUIButtons
    When set to '1', turns on the graphical buttons in the "Edit Page" form.
    # turn on graphical edit buttons
    $EnablePostAuthorRequired
    When set to '1', posting of pages requires the author to provide an author name. Otherwise, authors can post without a name.
    # require authors to provide a name
    $HandleEditFmt
    Like $HandleBrowseFmt, this specifies the entire output format for ?action=edit for a page.
    $IsPagePosted
    Set to a true value if the page is actually saved (e.g., this is used to tell the RecentChanges handlers if they need to update).
    $PageEditFmt
    By default, this is the HTML to be displayed for an edit form.
    $PageEditForm
    Specifies the edit form for ?action=edit. Defaults to '$SiteGroup.EditForm'.
    $ROEPatterns
    With this array you can add a pattern as key and set a text value which replace it on every edit request, using preg_replace function. Specifically it is replaced when the page is loaded into the editform, whenever a preview is done, and when the page is saved (from PmWiki 2.2.0beta45). See Cookbook:ROEPatterns for examples.
    $ROSPatterns
    With this array you can add patterns as key and set a text value which will replace it when the edited page is posted (as signaled by $EnablePost). It is not replaced when the page is loaded into the editform nor when a preview is done, but it is replaced only when the page is saved. See Cookbook:ROSPatterns for examples.
    This page may have a more recent version on pmwiki.org: PmWiki:EditVariables, and a talk page: PmWiki:EditVariables-Talk.
    Edit - History - Print - Recent Changes? - Search Page last modified on 2012-03-04 16:53 [UTC-7] - 949 views
