Recent Changes - Search:
go to the forum
Contents
Site
Help
« aug 2026 · dec 2026 »
    add a calendar item
    PmWiki / Markup Expressions
    authors (advanced)
    The {(...)} "expression markup" allows for a variety of string and formatting operations to be performed from within markup. Operations defined by this recipe include substr, ftime, strlen, rand, toupper / tolower, ucfirst, ucwords, pagename and asspaced.
    substr
    The "substr" expression extracts portions of a string. The arguments are
    1. the string to be processed. Always quote the string to be processed.
    2. the initial position of the substring. Note that the initial position argument is zero-based (i.e., the first character is referenced via a "0").
    3. the number of characters to extract
     {(substr "PmWiki" 2 3)}
     {(substr "PmWiki" 2)}
     {(substr "PmWiki" 0 1)}
     {(substr "PmWiki" 0 -3)}
     {(substr "PmWiki" -3)}
     Wik
     Wiki
     P
     PmW
     iki
    To obtain the last n characters of a string use {(substr "string" -n)}
    To truncate the last n characters of a string use (substr "string" 0 -n)}
    ftime
    "Ftime" expressions are used for date and time formatting. The generic form is
    {(ftime "fmt" "when")}
    {(ftime fmt="fmt" when="when")}
    where fmt is a formatting string and when is the time to be formatted. The arguments can be in either order and may use the optional "fmt=" and "when=" labels.
    Examples:
     {(ftime)}
     {(ftime fmt="%F %H:%M")}
     {(ftime %Y)}
     {(ftime fmt=%T)}
     {(ftime when=tomorrow)}
     {(ftime fmt="%Y-%m-%d" yesterday)}
     {(ftime "+1 week" %F)}
     {(ftime fmt=%D "+1 month")}
     {(ftime fmt="%a%e %b" when="next
    week")}
     2026-10-23 18:30  [UTC-7]
     2026-10-23 18:30
     2026
     18:30:57
     2026-10-24 00:00  [UTC-7]
     2026-10-22
     2026-10-30
     11/23/26
     Mon26 Oct
    The fmt parameter is whatever is given by "fmt=", the first parameter containing a '%', or else the site's default. The formatting codes are described at http://php.net/strftime. In addition to those, '%F' produces ISO-8601 dates, and '%s' produces Unix timestamps. Some common formatting strings:
         %F                # ISO-8601 dates      \"2026-10-23"
         %s                # Unix timestamp      "1792794657"
         %H:%M:%S          # time as hh:mm:ss    "18:30:57"
         %m/%d/%Y          # date as mm/dd/yyyy  "10/23/2026"
         "%A, %B %d, %Y"   # in words            "Friday, October 23, 2026"
    The when parameter understands many different date formats. The when parameter is whatever is given by "when=", or whatever parameter remains after determining the format parameter. Some examples:
        2007-04-11            # ISO-8601 dates
        20070411              # dates without hyphens, slashes, or dots
        2007-03               # months
        @1176304315           # Unix timestamps (seconds since 1-Jan-1970 00:00 UTC)
        now                   # the current time
        today                 # today @ 00:00:00
        yesterday             # yesterday @ 00:00:00
        "next Monday"         # relative dates
        "last Thursday"       # relative dates
        "-3 days"             # three days ago
        "+2 weeks"            # two weeks from now
    Note: If you want to convert a Unix timestamp you must prefix with the @. Thus, "{(ftime "%A, %B %d, %Y" @1231116927)}".
    The when parameter uses PHP's strtotime function to convert date strings according to the GNU date input formats; as of this writing it only understands English phrases in date specifications.
    The variable $FTimeFmt can be used to override the default date format used by the "ftime" function. The default $FTimeFmt is $TimeFmt.
    strlen
    The "strlen" expression returns the length of a string. The first argument is the string to be measured.
     {(strlen "{$:Summary}")}
     32
    rand
    The "rand" expression returns a random integer. The first argument is the minimum number to be returned and the second argument is the maximum number to be returned. If called without the optional min, max arguments rand() returns a pseudo-random integer between 0 and RAND_MAX. If you want a random number between 5 and 15 (inclusive), for example, use (rand 5 15).
     {(rand)}
     {(rand 1 99)}
     950014276
     20
    toupper / tolower
    The "toupper" and "tolower" expressions convert a string into uppercase or lowercase. The first argument is the string to be processed.
     {(toupper "{$:Summary}")}
     {(tolower "{$:Summary}")}
     STRING AND FORMATTING OPERATIONS
    ucfirst / ucwords
    The "ucfirst" expression converts to uppercase the first character of the string, and "ucwords", the first character of each word. The first argument is the string to be processed.
     {(ucfirst "{$:Summary}")}
     {(ucwords "{$:Summary}")}
     String and formatting operations
     String And Formatting Operations
    pagename
    The "pagename" expression builds a pagename from a string. The first argument is the string to be processed.
     {(pagename "{$:Summary}")}
     PmWiki.StringAndFormattingOperations
    asspaced
    The "asspaced" expression formats wikiwords. The first argument is the string to be processed.
     {(asspaced "{$FullName}")}
     Pm Wiki.Markup Expressions
    Nesting expressions
    Markup expressions can be nested:
     {(tolower (substr "Hello World" 2))}
     llo world
    Notes
    • For PmWikis version 2.2.33 or older, the string-processing expressions may not work properly on multibyte UTF-8 characters. Newer versions should work fine.
    See also
    This page may have a more recent version on pmwiki.org: PmWiki:MarkupExpressions, and a talk page: PmWiki:MarkupExpressions-Talk.
    Edit - History - Print - Recent Changes? - Search Page last modified on 2011-10-09 19:02 [UTC-7] - 707 views
