Recent Changes - Search:
go to the forum
Contents
Site
Help
« aug 2026 · dec 2026 »
    add a calendar item
    PmWiki / Markup Master Index
    %audienceAnonymous
    This page contains the most frequently used wiki markup, briefly. Follow the links in each section to learn more.
    Links
    See Links
    External links
    http://example.com
    [[http://example.com]]
    [[http://example.com | link text]]
    [[link text -> http://example.com]]
    Page links
    [[PageName]]
    [[page name]]
    [[page (name)]]
    [[PageName | link text]]
    [[PageName | + ]] (titled link)
    [[PageName | # ]] (anonymous numerical reference link)
    [[link text -> PageName]]
    [[#anchor]] (to create an anchor)
    [[#anchor | link text]] (to refer to an anchor)
    [[PageName#anchor | link text]] (to refer to an anchor in another page)
    See also WikiWord on how to enable WikiWord links.
    WikiGroup links
    See Links and Categories
    [[GroupName/]] or [[Group name/]]
    [[GroupName.]]
    [[GroupName/PageName]] or [[GroupName/page name]]
    [[(GroupName.)page name]]
    [[~Author Name]]
    [[!Category Name]]
    InterMap links
    See InterMap
    [[Path:/path/local_document.html]]
    [[Wikipedia:WikiWikiWeb]]
    Email links
    mailto:someone@example.com
    [[(mailto:)someone@example.com]]
    [[mailto:someone@example.com | display text]]
    [[display text -> mailto:someone@example.com]]
    Upload links
    See Uploads and Images
    Attach:file.odt
    [[(Attach:)file.odt]]
    [[Attach:file.odt | alternative text ]]
    [[Attach:file with spaces.pdf]]
    [[Attach:Groupname./file with spaces.pdf]]
    Images
    See Images and Uploads
    Images as Images
    http://example.com/image.gif
    http://example.com/image.gif"alt text"
    Attach:image.gif"My image"
    Attach:Groupname./image.gif"image in another group"
    Attach:Groupname.Pagename/image.gif"image on another page"
    %lfloat% Attach:image.gif | Caption %% (could be %rfloat%, %center%, %rframe%, %lframe% )
    %width=200px% Attach:image.gif %%
    %thumb% Attach:image.gif %%
    Images as links
    [[Attach:image.gif]]
    [[(Attach:)image.gif]]
    [[PageName | Attach:image.gif"alt text"]]
    [[http://example.com/ | Attach:image.gif"alt text"]]
    %rframe thumb% [[Attach:image.gif | Attach:image.gif"alt text"]] | Caption
    Start-of-line markup
    See Text formatting rules
    Lists
    See List Styles, Wiki styles and Cookbook:Outline lists
    * unordered list
    ** deeper list
    # ordered list
    # %item value=#% arbitrary start number
    # %decimal%, %roman%, %ROMAN%, %alpha%, %ALPHA%
    :term:definition
    Also
    Q: start a question paragraph
    A: start an answer paragraph
    Headings
    !! Heading
    !!! Deeper heading
    Paragraph blocks
    -> indented text
    -< hanging indent
    <space> preformatted text
    [@...@] preformatted block
    ---- (horizontal rule)
    blank line is vertical space
    \ at end of line joins next line
    \\ at end of line produces a line break
    \\\ at the end of a line produces a blank line, even within a list item
    [[<<]] produces a line break that clears floating content
    Division blocks
    See Block markup?, Wiki styles and Page directives
    >>wikistyle<<
    (:div class="" style="":)
    (:divend:)
    Text markup
    Character format
    ''emphasized''
    '''strong'''
    '''''strong emphasis'''''
    @@monospaced@@
    [-small-], [--smaller--]
    [+big+], [++bigger++]
    '-small-', '+big+'
    '^superscript^', '_subscript_'
    {+inserted+} (underscore)
    {-deleted-} (strikethrough)
    [@escaped code@]
    [=escaped text=]
    Posting markup
    ~~~ (author's signature)
    ~~~~ (author's signature and date)
    (:encrypt phrase:) -- replaced with encrypted form of phrase
    Tables
    Plain rows and columns of text
    See Tables
    ||table attributes
    ||!table caption!||
    ||left aligned || centered || right aligned||
    ||!column heading||
    ||spanned columns ||||||
    Structured tables
    See Table directives
    (:table attr:)
    (:cellnr attr:)
    (:cell attr:)
    (:tableend:)
    Directives
    Page directives
    See Page directives
    (:redirect PageName:)
    (:(no)spacewikiwords:)
    (:(no)linkwikiwords:)
    (:(no)linebreaks:)
    (:nl:) insert newline in the *markup* only if one isn't present. The purpose of (:nl:) is to be able to write things like:
    (:include Page1:)(:nl:)(:include Page2:)
    which guarantees that the first line of Page2 is treated as a separate line from the last line of Page1, but without inadvertently generating a blank line between them.
    Display
    See Page directives Group headers
    (:noheader:), (:nofooter:)
    (:notitle:)
    (:noleft:), (:noright:)
    (:nogroupheader:), (:nogroupfooter:)
    (:noaction:)
    Metadata
    See Page directives, Comment markup, Page variables
    (:title text:)
    (:keywords word, ...:)
    (:description text:)
    (:comment text:)
    {Group/PageName$:Var} includes from (:name:text:)
    Include
    See Include other pages, Page text variables
    (:include PageName:)
    (:include PageName#start#end lines=n paras=n:)
    (:include Page1 Page2 Page3:)
    Conditional markup
    See Conditional markup
    (:if (!) cond param:)...(:ifend:)
    (:if (!) cond param:)...(:else:)...(:ifend:)
    (:if (!) cond param:)...(:elseif (!) cond param:)...(:ifend:)
    Pagelists
    See Page lists
    (:searchbox label=label order=-time:)
    (:searchresults incl -excl group=abc fmt=def:)
    (:pagelist incl -excl group=abc fmt=def:)
    Other directives
    See Page directives
    (:PageDirectives#markup:) [=...=]
    (:markup:)...(:markupend:)
    (:markup class=horiz:)...(:markupend:)
    (:markup caption='...':)...(:markupend:)
    (:messages:)
    Forms
    See Forms
    (:input form method=get action=url enctype=multipart/form-data:)
    (:input default name=xyz value="abc":)
    (:input text name=first value="Bob" size=20:)
    (:input textarea name=xyz [=value=] rows=2 cols=80:)
    (:input submit name=post value="Go" accesskey=g:)
    (:input reset:)
    (:input hidden name=action value=edit:)
    (:input radio name=xyz value="abc" checked=1:)
    (:input checkbox name=xyz value="abc" checked=1:)
    (:input password name=authpw:)
    (:input file name=upload:)
    (:input image name=xyz src="http:..." alt="Alt Text":)
    (:input select name=xyz value="val1" label="Value 1":)
    (:input select name=xyz value="val2" label="Value 2":)
    (:input end:)
    See also PmWiki Edit forms.
    Wiki trails
    See Wiki trails
    <<|[[TrailPage]]|>>
    <|[[TrailPage]]|>
    ^|[[TrailPage]]|^
    Page variables
    See Page variables, Page text variables, Page lists
    {$variable}
    {pagename$variable}
    (:name:description:) sets a page text variable
    Expressions
    See Markup expressions
    {(function args)}
    This page may have a more recent version on pmwiki.org: PmWiki:MarkupMasterIndex, and a talk page: PmWiki:MarkupMasterIndex-Talk.
    Edit - History - Print - Recent Changes? - Search Page last modified on 2012-10-14 15:42 [UTC-7] - 1027 views
