Recent Changes - Search:
go to the forum
Contents
Site
Help
« aug 2026 · dec 2026 »
    add a calendar item
    Schematics / VCO 555 By Thomas Henry
    < Bi-N-Tic Filter by Ken Stone | Schematics | MS20 inspired VCO by Pantheon >
    < Grant Richter's Wogglebug | Listbytype | MS20 inspired VCO by Pantheon >
    DIY | VCO | 555 | Thomas Henry
    VCO555 by Thomas Henry presented by himself on the following thread : http://electro-music.com/forum/viewtopic.php?t=54623 from there his description on this circuit : Hi all,
    As alluded to previously, I have four projects that have been sitting around way too long and have been panting to get out the door for the past couple of years.
    So, here's the first: VCO using easy to find parts. If I may be so immodest, this is my best design to date. The waveforms look great and if you check the measurements, below, you'll see it's the most accurate I've ever come up with. If I were younger and had more energy, I'd turn this into an article and make some moolah from it. Unfortunately, my strength for such endeavors is ebbing, so instead I'll post it here for you to play with. All I ask is that you respect the rights and don't republish the design or rip it off for any commercial purposes. I'm not opposed to someone doing a PCB for noncommercial uses, but please secure permission from me first.
    Okay, without that out of the way, here's the dope. My favorite VCO of all times is the CEM3340, and I've always wanted to approximate it somehow. After nearly thirty years, I finally have a design which comes the closest. The accuracy on my breadboard was very good.
    There are ramp, triangle, pulse and sine outputs, all of which are decent looking. The sync is a real treat and basically comes along for free. And, of course, there are the usual VCO features such as coarse and fine tuning, exponential and linear FM, etc. If you're looking for cleverness, then be sure to check out how I did the sync, the ramp, and buffered the sine to keep the chip count down.
    So there it is. Have fun with it and be sure to post your results here. Three modules are in the wings and should be out the door in the next week or so. And then school starts yet again and another year evaporates...
    Thomas Henry
    Edit - History - Print - Recent Changes? - Search Page last modified on 2013-02-24 13:55 [UTC-7] - 5542 views
