Posted: Fri Jun 20, 2014 3:47 am Post subject:
german
i should have asked first, i see. although MULTIPLE is a compromise due to the space i had for the writing. Amplitude seems german enough to me, although your suggestions are better. i think i will change that.
Joined: Apr 14, 2013 Posts: 21 Location: Arkansas, USA
Posted: Fri Jul 04, 2014 10:43 am Post subject:
One of my first contributions here! I've been building kits in Eurorack format, and slowly designing my own circuits. My goal is to have my whole system DIY.
Here's a few from Barton Musical Circuits.
Thanks for all of your inspiration and help and an awesome community!
Barton Dual LFO and S&H billsship
Filesize:
49 KB
Viewed:
611 Time(s)
Barton Dual LFO and S&H billsship 2
Filesize:
73.67 KB
Viewed:
721 Time(s)
Barton Quad VCA / Mixer billsship
Filesize:
45.54 KB
Viewed:
636 Time(s)
Barton Full Wave Dual Rectifier wood panel from a clipboard billsship
Filesize:
109.93 KB
Viewed:
633 Time(s)
Four Barton Analog Drums spraypainted billsship
Filesize:
210.81 KB
Viewed:
651 Time(s)
Latest addition: a module I've called Second String. Basically an 8 step sequencer with three separate outputs, each step of which is independently controllable to put out between 0 and 16 semi-tones of CV. Intended to allow chords to be built using 3 or 4 VCOs (one to supply the root note, either 2 or 3 for the notes of the chords). Alternatively, one output can control a separate VCO, eg as a bass, in the attached sample.
Rats nest of wiring as you can see. And as for the panel - that's 24 4-way DIP switches, and 96 resistors!
second string sequence.mp3
Psynth - Second String noodle Monkey Cymbals, Bass++ at 15s, Since VCO Bass line controlled by Second String at 25s, Root square wave VCO at 37s, 2nd and 3rd strings at about 1 min.
Filesize:
4.2 MB
Duration:
2:18
Viewed:
2064 Time(s)
Filesize:
991.95 KB
Viewed:
378 Time(s)
Filesize:
1018.4 KB
Viewed:
571 Time(s)
Filesize:
986.97 KB
Viewed:
487 Time(s)
Filesize:
842.72 KB
Viewed:
396 Time(s)
Posted: Thu Jul 31, 2014 10:30 pm Post subject:
That's a pretty neat idea!
I'm frightened to ask how long wiring it up must have taken, though
I'm frightened to ask how long wiring it up must have taken, though Shocked
A fair few hours
Actually, debugging was the worst part. All those resistors and wires soldered to a small piece of stripboard = plenty of opportunity for shorts. Also, I had some msyterious errors in voltages which I finally tracked down to the residue from the no-clean solder, forming a resistance in parallel with my supposedly matched 100k's.
Also sduck your panels looks amazing.
I think I'll start using FPE to make custom panels.
Thanks! Yes, I like FPE, after getting over the learning curve part of their design program. Kind of expensive, but the results are great, so it's worth it.
Haven't checked in here in a while, and forgot to post this here -
this new build has 2 x 258 VCO's ,TZERO VCO from Electronotes ,Serge VCS ,2 x LFO's , MFOS VCA x 2, ARP VCF , Analog Neuron ,Mixer , Roland 100M ADSR ,Portamento and lot of wires ,happy with how it turned out ,the colorful panel pic is photoshop
Filesize:
1 MB
Viewed:
431 Time(s)
Filesize:
1009.29 KB
Viewed:
402 Time(s)
Filesize:
1.61 MB
Viewed:
415 Time(s)
Filesize:
1.03 MB
Viewed:
444 Time(s)
Filesize:
1.47 MB
Viewed:
463 Time(s)
Thanks ,i'm happy with this build overall ,could have picked other wood material for the case maybe ,audio i have some but i gotta say poor quality from my cheap souncard ,some noise in the back, i'm posting it anyay ,these are the buchla 258's ,in tune ,and some other patch ,btw using a 208 Random just to play a seq ,this box is missing a s/h for sure ..btw made some great glithy patches but the soundcard is so bad didn't dare to record , the neuron has anextra input and the mixer has 3 outputs for lot of feedback crazyness
Thanks Phobos i enjoyed making it .Muied Lumens i didn't had the chance really to explore it's sounds well ,i think it is capable ,but you can hear the recordings are noisy and i also think missing a lot of detail ,anyway ...what's next to build _________________ http://synthacks.blogspot.com/ шематикс
Posted: Sun Aug 31, 2014 1:59 am Post subject:
So, what did you spend your weekend on?
The synthcube box arrived Friday, and I got a case of the enthusiasms.
Some problems arose.
One, Gate Bus 3 didn't work. A bit of time with the multimeter and the cable charts from the original build doc, and I found that stabbing one of the crimped connectors hard with a screwdriver fixed it.
Two, 4 Oct won't bloody calibrate. Oh well, I don't care. I'll use the variable range for that.
Three... my ghetto diy case has now run out of room
