Joined: Oct 29, 2012 Posts: 21 Location: Poland, Poznan
Posted: Wed Oct 31, 2012 2:00 am Post subject:
Hallo,
this is my first synth - Stylophone clone (100% analog), enclosure contain parts from '70 laboratory equipment. Second synth - MFOS Sound Lab (uses one-side board), from 2011/2012.
Custom designed PCB, obsolete components.
Filesize:
1.01 MB
Viewed:
750 Time(s)
Cheap plastic and aluminium.
Filesize:
632.17 KB
Viewed:
783 Time(s)
Soundlab in compact case.
Filesize:
842.11 KB
Viewed:
797 Time(s)
Uses custom designed one-side, home-etched PCB.
Filesize:
245.54 KB
Viewed:
742 Time(s)
Posted: Thu Nov 01, 2012 9:48 am Post subject:
Thanks,
I had to design new panel because I couldn't get bigger enclosure. When I printed it, I realized, there is no "trigger" button and it doesn't fit in "envelope section". Then I saw Dave Smith Instruments Mopho with "push it" button - so i decided to put "trigger" in the center and expose it somehow.
The knobs are really nice and small, and fit great in such tight panel. And are only 30 cents.
Posted: Tue Nov 06, 2012 8:31 pm Post subject:
A side trip in the Time Machine
MANY thanks to Synthcube for the kit that made this possible. Once I started I couldn't stop. Easy peasy, built it in 2 days, basically. It might help that I was familiar with the circuit from troubleshooting another one, but there you go
The audio is a triangle in, regen set to max negative and modulation by the LFO on its slowest setting, for the first minute or so, an then noodling with knobs after that.
tm2050-1.mp3
Filesize:
4.65 MB
Duration:
5:05
Viewed:
2686 Time(s)
Filesize:
533.6 KB
Viewed:
530 Time(s)
Filesize:
528.31 KB
Viewed:
485 Time(s)
so i eventually finished the mutant vactrol filter of our much-loved mr scott stites (using a PCB i bought over at muff's):
Tech Buddy at Random*Source Last edited by fonik on Wed Nov 21, 2012 4:19 pm; edited 1 time in total
cute minisynth!
your stuff ´looks so awesome. it has character! _________________
Posted: Wed Nov 21, 2012 9:38 pm Post subject:
Utility Distribution Module
Trigger/Gate mults and CV mults (including offset) built from MFOS CV/Gate distributor schematics (though I omitted the offset from one CV buffer), and Sum/Difference circuit found somewhere else. Built the three sections on separate boards and then had merry hell trying to figure out how to mount them on such a dense panel. Ended up building a stooge panel (?) from the flashing from Home Depot that others have talked about.
Not tested yet, but I'm pretty happy with the layout and wiring....
Filesize:
213.75 KB
Viewed:
1073 Time(s)
Filesize:
295.67 KB
Viewed:
1093 Time(s)
One of those lo-fi radio shack "voice recorder" modules ($10), set up as a looper. the rca jack goes to a foot switch for recording. the knob controls the supply voltage, which slows things down.
Filesize:
393.15 KB
Viewed:
1140 Time(s)
Audio files: 172
Posted: Thu Nov 22, 2012 1:19 pm Post subject:
dave_3283 wrote:
In a month, I went from completing my first module to this:
I've now got 4 Schmitz/CGS VCAs, 2 MFOS ADSRs, a MFOS State Variable Filter, and a MFOS Low Pass. Next up, a quadruple CGS LFO and 2 CGS VCOs...
And a lovely case too. Do you have VCOs already to run through it? _________________ Garret: It's so retro.
Parker: Like, old and outdated. Home,My Studio,and another view
Posted: Thu Nov 22, 2012 4:00 pm Post subject:
Thanks! I've got a pair of Plan Bs just out of frame that I'm about to sell off. They will be replaced by a pair of CGS oscillators as well as a quadruple Utility LFO in the next week or two.
Audio files: 730
Posted: Mon Nov 26, 2012 9:38 am Post subject:
Enneatronic Spectralizer Subject description: Dronebox with 9 squarewave oscillators
This is a circuit that I probably build 5 or 6 years ago, but I still had to put it in an enclosure. I originally planned
to make it into a cube shape (maybe use a photocube), but then I remembered this box I got not too long ago.
I expected it to be to small, but it was perfect!
The circuit itself contains 9 (tunable) squarewave oscillators for the sound, and 9 (non tunable) squarewave oscillators
that together with some resistors, caps and transistors create a fading effect (both for LED's and sound).
It has a build in speaker + amp with volume control, but you can also plug in some headphones. I wired the output of the
amp to the tip and ring of the jack (sleeve not connected). So you can plug in a stereo pair.
The line out is actually a stereo jack that functions as a EFX S/R for the build in amp. So you can add effects while
listening through speaker or headphones
I posted a recording last week which you can find here
and here's a video
Filesize:
72.08 KB
Viewed:
1081 Time(s)
Filesize:
65.42 KB
Viewed:
1124 Time(s)
Filesize:
82.82 KB
Viewed:
1162 Time(s)
Filesize:
44.61 KB
Viewed:
1130 Time(s)
Posted: Mon Nov 26, 2012 12:30 pm Post subject:
Re: Enneatronic Spectralizer Subject description: Dronebox with 9 squarewave oscillators
Nice work. Found a pic of someone viewing that display
Filesize:
77.52 KB
Viewed:
33568 Time(s)
_________________ Revenge is a dish best served with a fork... to the eye
Audio files: 730
Posted: Tue Nov 27, 2012 6:21 pm Post subject:
elmegil wrote:
What are the 4 switches for?
The oscillators are divided in 3 groups (of 3) and with the first 3 switches from the left I can turn the audio of
each group on/off, which makes tuning a bit easier. The switch next to those 3 is to turn the display on/off,
and the switch above the LED is the power switch. _________________ "My perf, it's full of holes!" SoundCloudBandCampMixCloudTwitchYouTube The Golden Shrimp Guild Last edited by PHOBoS on Wed Nov 28, 2012 2:54 pm; edited 1 time in total
