Posted: Tue Oct 25, 2005 12:12 am Post subject:
Machine DRUM II
not really an elektron machinedrum-clone (sorry to dissapoint you if you were expecting this )
but a reworked version of richard devine's "machine DRUM 2" patch
I've added some new features like a mod env for the filters, a new fx section (3 bands distortion-unit with compressor),
a re-trigger function, a new mixer, knobs assignments new presets and 4 morph groups
morph group 1 (modwheel) : re-trigger function, move modhweel for re-triggering, adjust interval with the clockdivider and rnd-trigger
morph group 2 (page E:1) : morph effect, various parameters are assigned to this, move it to hear the effect
morph group 3 (page E:1) : morph effect, various parameters are assigned to this, move it to hear the effect
morph group 7 (pitchstick) : morph effect, this is a copy of morph group 2 or 3, but bi-polar instead of unipolar
you can do some crazy stuff with these morphs, certainly when you combine them, check audio example for a little demonstration.
This is a just a loop of 16 steps long (with no modulations) but if you tweak the morphs (and I've *only* tweaked the morphs during
that recording, nothing else) it gives this kind of result (check mp3 for example, the first 10 seconds is the loop without morph tweaks)
enjoy!
MD2MMAE_ROOM121.MP3
audio example Machine DRUM II with various morph tweaks
Filesize:
2.04 MB
Duration:
1:29
Viewed:
3297 Time(s)
MACHINE_DRUM_2MM.PCH2
reworked version of richard devine's machine DRUM II.
Tweak morphs for effects
Posted: Fri Jun 08, 2007 3:26 am Post subject:
Re: Machine DRUM II
doesn't matter because i have a MD
de mp3 sounds wicked, can't wait to load this patch in my g2
thanks
Posted: Sat May 16, 2009 9:40 am Post subject:
hi Mother Misty i want know if there is a patch of drums that are not sequenced, i want play this patch like a drumkit by my sequencer live 7 or the keys of g2.
i m at first arms with g2 and his editors.
bye Dido
bye Dido
Hi dido!
sorry for the late reply. I've changed the patch a little bit, now you can sequence it from a DAW. (keymappings are kick=C0, perc=D0, SHPOSC=E0, SHPOSC 2=F0)
(Basicly, you just have to replace the trigger outputs from the sequencer with a note receive module in order to make this patch work with a DAW)
misty.
EDIT: you still need to change the value of the midi-note receive modules (top left) in the other variations, only works correctly in the 1st variation of the patch now.
