Recent Changes - Search:
go to the forum
Contents
Site
Help
« aug 2026 · dec 2026 »
    add a calendar item
    PmWiki / Inter Map
    (redirected from PmWiki.CustomInterMap)
    author (intermediate)
    The InterMap (also called InterWiki in some other wikis) is a system for defining links between WikiWikiWeb sites that was first developed by UseMod and Meatball (see UseMod:InterWiki and Meatball:InterWiki). The method is to use a word shortcut that stands for a defined path. InterMap links have the form MapPrefix:PagePath, where the host prefix is converted to a partial URL based on entries in the site's intermap.txt and localmap.txt files.
    The default intermap.txt
    The default intermap.txt distributed with PmWiki (in the scripts/ directory) includes the following InterMap entries:
    The page Site.InterMap?
    You can map your own prefixes in your local page Site.InterMap?.
    Thus, "PmWiki:Variables" becomes "http://www.pmwiki.org/wiki/PmWiki/" + "Variables," a link to the PmWiki.Variables page on the official PmWiki web site, Wiki:FrontPage is a link to the front page of the first WikiWikiWeb, and Wikipedia:Stonehenge takes you to the Wikipedia article about the famous megaliths in England.
    Usage in a wiki page
    Like other links, you can use the double-bracket syntax to get different link text:
    * [[Meatball:StartingPoints | starting
    points]] over at Meatball
    * [[starting points ->
    Meatball:StartingPoints]] over at
    Meatball
    If you want to link just to what the intermap says (e.g. http://www.wikipedia.com/wiki/ for Wikipedia), then do [[Wikipedia:. | Wikipedia's main page]], which produces Wikipedia's main page. Note the . (period) after the Map: reference.
    The special Path: InterMap entry can be used to create "relative urls" in links.
    Custom InterMap prefixes
    The actual set of InterMap links at any site is defined by the site administrator via the Site.InterMap? page and the local/localmap.txt file.
    An intermap entry takes the following format:
    MapPrefix:      http://example.com/partial/url/
    The InterMap entry can be for any of the link schemes supported by PmWiki.
    You can create your own InterMap links by doing one or more of the following:
    • Modify the page called Site.InterMap? and place entries like the ones above in it.
    • Create a file called local/localmap.txt and place entries like the ones above in it.
    • In a WikiFarm installation you can create a file called local/farmmap.txt and there place entries like the ones above in it. These prefixes will be common to all the wikis in the farm.
    • Ensure that there is a space after the colon.
    Do not edit the file scripts/intermap.txt directly! If you do, you'll lose your changes when you upgrade PmWiki.
    Variables and InterMap links
    It's possible to use variables within your InterMap entries. The following entries create ThisWiki: and ThisPage: shortcuts:
    ThisWiki:        $ScriptUrl
    ThisPage:        {$PageUrl}
    You can also define InterMap entries where the text of the entry is substituted into the middle of the URL. Just include '$1' in the URL where you want the substitution to take place. For example:
    Jargon: http://catb.org/~esr/jargon/html/$1.html
    would cause Jargon:F/feature-creep to be converted to http://catb.org/~esr/jargon/html/F/feature-creep.html.
    Tips and tricks
    It is possible to document your intermap prefixes directly in the page Site.InterMap?. The extra text will not cause a performance penalty, nor will it break the definition of prefixes. However, be aware that anything matching a line starting with a word and a colon (:) will be considered to define a prefix.
    The order in which various sources are checked for definitions of prefixes is controlled by the variable $InterMapFiles. Currently the precedence (highest to lowest is as follows):
    Are InterMap names case sensitive?
    Yes, thus eAdmin: is a different InterMap link than EAdmin:.
    How can I achieve a localmap.txt mapping with the effect of Pics: Path:/somepathto/pics/?
    Use the following:
    Pics: /somepathto/pics/
    How can I define an InterMap in PHP?
    Use the following:
          $LinkFunctions['PmWikiHome:'] = 'LinkIMap';
          $IMap['PmWikiHome:'] = 'http://pmwiki.org/wiki/$1';
    This page may have a more recent version on pmwiki.org: PmWiki:InterMap, and a talk page: PmWiki:InterMap-Talk.
    Edit - History - Print - Recent Changes? - Search Page last modified on 2012-07-10 09:05 [UTC-7] - 1102 views
