Coming up on Radio 1 at
The Moduletta
Page 2 of 3 [63 Posts]
synaesthesia
Audio files: 87
PostPosted: Tue Apr 12, 2016 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Two more patches from the Moduletta. The first is using an 8-bit shift register with XOR feedback and a filter. The second uses two counters at different speeds for the melody and a shift register to generate the second voice.
Moduletta Chimes Bass.mp3
 Filesize:  1.08 MB
 Viewed:  2288 Time(s)
Moduletta Swing Melody.mp3
 Filesize:  588.69 KB
 Viewed:  2153 Time(s)
masterofstuff124
PostPosted: Fri Apr 15, 2016 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow this looks amazing. Id love to get a PCB. Im currently building a benjolin and power supply with 12v out so I can connect it with breadboard circuits and patch them to the benjolin. Going for a poor mans sound machines ns1 http://www.sound-machines.it/product/ns1nanosynth/ this "moduletta" seems like it would fit great into that plan. I hope you make the pCB's available!
a fellow sound enthusiast!
synaesthesia
Audio files: 87
PostPosted: Sun Apr 17, 2016 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
And two more patches. The first is made from a shift register and a counter to generate random beats with small variations. The second is the famous Rungler made from an 8-bit shift register and two VCOs with PWM.
Moduletta Beatbox.mp3
 Filesize:  472.35 KB
 Viewed:  2124 Time(s)
Moduletta Rungler.mp3
 Filesize:  500.92 KB
 Viewed:  2125 Time(s)
trav
Audio files: 17
PostPosted: Sun Apr 17, 2016 6:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
These sound great! Favourites so far are the Swing Melody and Chimes Bass.
piedwagtail
PostPosted: Mon Apr 18, 2016 10:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like the logistics of this: negotiating with a mustard factory for knob supply.
Even the conversation where someone says "this would make a good..."
There should be more synth/catering interaction.
With the bun* colour MDF and the mustard knobs, I feel the pcbs should be red! Smile
Superb work, gentlemen.
R
*bread roll or the precise german word for such I don't know
Kosmo Mishka
PostPosted: Tue Apr 19, 2016 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Thats great! Sound and design so beautiful. If there will be a chance, I would like to buy couple pcbs or kits.
synaesthesia
Audio files: 87
PostPosted: Fri Apr 22, 2016 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't stop. Two more sound samples from the Moduletta. The first is using a shift register for a randomized scale and another one for the arpeggios. The VCA gives it the percussive touch. The second patch uses a long counter for scale and rhythm and a long shift register as a variable divider. It is a bit heavy on the low frequencies, so sounds better using headphones.
The patches are documented and I will publish them together with the schematics and description for the workshop soon.
Moduletta Rock.mp3
 Filesize:  1.23 MB
 Viewed:  2056 Time(s)
Moduletta March.mp3
 Filesize:  1.13 MB
 Viewed:  2049 Time(s)
piedwagtail
PostPosted: Sat Apr 23, 2016 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
(prompt)
Will you video the workshop?
R
synaesthesia
Audio files: 87
PostPosted: Sat Apr 23, 2016 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, now that you ask, I think it would be a good idea. Given that everybody agrees of course.
elektrouwe
PostPosted: Sun Apr 24, 2016 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
moduletta spring version : mustard CVs and tomato Env. and Vol. Smile
will post some knob making info in DIY Hardware and Software
 Filesize:  729.12 KB
 Viewed:  618 Time(s)
piedwagtail
PostPosted: Sun Apr 24, 2016 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Is that paint or recycled plastic?
R
elektrouwe
PostPosted: Sun Apr 24, 2016 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
R
it's painted MDF
Audio files: 353
PostPosted: Sun Apr 24, 2016 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just listened to the sound examples, it does some nice stuff!
phobos
Audio files: 728
PostPosted: Mon Apr 25, 2016 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice sounds! Very Happy
and I love the look of that spring version (with the LEDs in the same order as I would place them Rolling Eyes )
The Golden Shrimp Guild
1_over_f_noise
PostPosted: Sat Apr 30, 2016 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi elektrouwe,
how you obtained the Moduletta PCB? Or did you make by yourself?
synaesthesia
Audio files: 87
PostPosted: Sat Apr 30, 2016 11:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I designed the circuit and PCB and had it manufactured at vrint-pcb. Uwe helped with the PCB design and did the laser cutting. Of course, he got the first PCB for that. Looking forward to the workshop now.
stringsthings
PostPosted: Fri May 13, 2016 2:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Interested in a PCB when available
synaesthesia
Audio files: 87
PostPosted: Tue Jun 07, 2016 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can find a few photos from the ZUKUNFTSMUSIK workshop in Linz at http://dorninger.servus.at/node/1824. We built several Modulettas there and demonstrated them during an improvised performance on the last evening.
synaesthesia
Audio files: 87
PostPosted: Sun Jul 24, 2016 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
My recording works again. Very Happy I couldn't make my laptop accept audio input via the combo input jack any more, so I bought a small USB soundcard. It was really cheap, but works great in combination with Audacity.
This patch uses the Moduletta plus two extra prototype modules that I built recently. The first is a voltage controlled hex wave folder, and the second is a PT2399 based delay. Enjoy the recording!
For those with a Moduletta, here is the patch. Just skip the folder and delay for now and connect VCO3:ANA to MIXER:ME and SHIFTER2:Q0 to MIXER:LO.
Code:
CV1->VCO1:CV
VCO1:DIG->COUNTER1:CLOCK
COUNTER1:Q0->VCO3:GATE
COUNTER1:Q1->SHIFTER2:XOR_D2
COUNTER1:Q3->SHIFTER1:CLOCK
VCO3:DIG->SHIFTER2:CLOCK
SHIFTER2:Q2->SHIFTER2:XOR_D1
SHIFTER2:Q3->SHIFTER1:XOR_D1
SHIFTER1:Q0->DAC1:CV/2
SHIFTER1:Q1->DAC1:CV/1
SHIFTER1:Q3->DAC1:CV/4
LOGIC:HIGH->DAC1:CV/1
DAC1:OUT->VCO3:CV
SHIFTER2:Q0->DAC2:CV/1
VCO3:ANA->FOLDER:IN
VCO1:ANA->FOLDER:CV
FOLDER:OUT->DAC2:CV
DAC2:OUT->DELAY:IN
DELAY:OUT->MIXER:LO
Moduletta Delay.mp3
 Filesize:  2.49 MB
 Viewed:  1860 Time(s)
Kosmo Mishka
PostPosted: Thu Jan 12, 2017 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Still want this
soundworker
PostPosted: Tue Jan 17, 2017 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
My Moduletta is just ready.
Best sounding filter with 9 Volts, regulated.
Jimi-Modulier-da.mp3
Pure Moduletta sound, only a bit of Federhall.
Klangbaukoeln
 Filesize:  3.13 MB
 Viewed:  1914 Time(s)
haebbmaster
PostPosted: Tue Nov 28, 2017 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
VCO is ready, thank you for this
 Filesize:  149 KB
 Viewed:  440 Time(s)
 Filesize:  112.46 KB
 Viewed:  439 Time(s)
Make modular synthesizers great again!
Modular Synthesizer DIY blog: http://modular.haebbmaster.de
synaesthesia
Audio files: 87
PostPosted: Wed Nov 29, 2017 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great to see other Modulettas! Here is the documentation that I prepared for the workshop. I translated the most important parts to English by now. The descriptions of the sample patches are still in German, but I believe you can easily figure out how the connections have to be made from the tables.
Moduletta (English).pdf
 Filename:  Moduletta (English).pdf
 Filesize:  1.84 MB
 Downloaded:  730 Time(s)
haebbmaster
PostPosted: Sat Dec 02, 2017 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for the documentation.
This is the dual filter. I added potentiometers for attenuting the CV
On the VCOs I added CV potentiometers too and normalized them to + so they work without a CV.
 Filesize:  73.49 KB
 Viewed:  433 Time(s)
 Filesize:  124.96 KB
 Viewed:  471 Time(s)
gasboss775
PostPosted: Tue Dec 05, 2017 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
A bit late to the party, I know. Are there any PCBs still available for this project?
BTW the VCO works using an NPN transistor instead of the 4066, though it gets quite non linear below about 75 millivolts input CV.
