Buying Japanese domestic studio gear: five checks before the voltage converter
RenSynthJp
PostPosted: Wed Sep 30, 2026 9:10 am    Post subject: Buying Japanese domestic studio gear: five checks before the voltage converter Reply with quote  Mark this post and the followings unread
Japanese used-audio listings are full of equipment that is familiar by brand but unfamiliar in its domestic-market version. The obvious warning is 100 V mains power, yet voltage is only one of several checks that matter before importing a recorder, monitor, effects unit or desktop amplifier.
1. Read the rear panel, not the seller's title
Many listings use a family name that covered several regional versions. A rear-panel photograph should show rated voltage, frequency, power consumption and the exact model suffix. If the label says AC 100 V, a plug-shape adapter does nothing useful; it changes the connector, not the voltage. A proper step-down transformer must be sized above the unit's consumption with headroom, and it should be appropriate for continuous audio use.
Some modern devices avoid the issue with an external universal-input supply marked 100–240 V, 50/60 Hz. In that case the supply label is the important photograph. USB-powered recorders, interfaces and small effects boxes may also be region-independent, but that should be confirmed model by model rather than inferred from the brand.
2. Separate the Japanese model from the export model
Sony's MDR-CD900ST is a good example of a domestic product that looks almost like a globally familiar one while occupying a different place in Japanese studios. The same problem appears with Tascam recorders, Zoom handhelds, Korg desktop instruments and Yamaha monitor or mixer variants: a similar enclosure does not prove identical connectors, bundled supply, firmware or radio certification.
Search the complete model string in Japanese and compare the manufacturer's manual. `取扱説明書` means instruction manual, `付属品` means included accessories, and `動作確認済み` means operation has been checked. `通電確認のみ` is much weaker: only power-on was confirmed.
3. Treat old rechargeable batteries as consumables
Portable recorders, MiniDisc units, field players and wireless accessories are often photographed with their original battery. That is not evidence of useful capacity. Check whether the compartment takes ordinary cells, a proprietary pack or an internal battery, and whether replacement packs are still available. Corrosion in a battery compartment is more important than light case wear.
For equipment with memory cards or removable media, confirm the largest supported capacity and format. A recorder built around an older SD standard may reject a modern high-capacity card even though the card physically fits.
4. Ask what was actually tested
`音出し確認済み` means sound output was checked, but it does not necessarily cover every input, output, encoder, fader or recording mode. For a multichannel device, useful evidence is a photograph or short test showing each channel passing signal. Scratchy pots, dim displays and intermittent jacks may not appear in an overall grade.
Japanese condition phrases help triage listings: `ガリあり` indicates scratchy pot noise; `液晶薄い` means a faint LCD; `ジャンク` means junk/as-is; and `現状品` means sold in its present condition. Neither of the last two should be read as a repair diagnosis.
5. Budget from packed dimensions
A rack unit, pair of monitors or turntable can be light relative to its carton and still bill at volumetric weight. Original packaging can be valuable for protection, but it also changes the shipment size. Large speakers and turntables need a packing plan that immobilises drivers, platters and tonearms; merely adding bubble wrap around the retail box is not the same thing.
Also keep restricted consumables out of the parcel. Aerosol contact cleaner, spray lubricant and some battery types can change carrier eligibility. Buy the chemistry locally and check batteries against the chosen carrier's current rules.
Disclosure: I work with the OneMall team, a Japan proxy-shopping service. I adapted this checklist from our broader map of Japanese audio brands and domestic model families, so the source is commercial rather than independent buying advice. The longer brand guide is here. OneMall does not independently assess equipment condition.
For anyone who has imported Japanese studio gear: which model suffix, power-supply detail or supposedly minor accessory caused the biggest surprise?
