AS3320 vcf schematic checkup
Page 1 of 1 [7 Posts]
AmpedVoltz
PostPosted: Fri Apr 17, 2020 8:11 am    Post subject: AS3320 vcf schematic checkup Reply with quote  Mark this post and the followings unread
Hi synthfolks!
A while ago I've made a schematic for a filter based on the AS3320. One module contains 3 vcf's.
Now when I was testing the pcb's, there was only 5V coming out of the module. So maybe someone could have a look at the schematic for just one filter, and help me find my error? Smile
Thanks anyway! AV
https://docdro.id/o5E4nAj
PostPosted: Sat Apr 18, 2020 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
How are you measuring this voltage? Ac or DC? And where?
If you are measuring at the AUDIOUT1:
Since this output is capacitively coupled with a resistor to GND level, you should be measuring no DC voltage.
my synth
AmpedVoltz
PostPosted: Sat Apr 18, 2020 3:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, thanks for your reply!
I was using an oscilloscope to measure ac voltage.
When testing the circuit, I've noticed that the AS3320 was getting a little hot.
PostPosted: Sat Apr 18, 2020 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where did you measure 5 volt?
my synth
AmpedVoltz
PostPosted: Sun Apr 19, 2020 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Just right out of the output...
PostPosted: Mon Apr 20, 2020 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
If you followed the diagram correctly, it is not possible to measure a dc voltage at the output.
So check check, double check your build.
my synth
Electric Druid
PostPosted: Sun May 31, 2020 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey AmpedVoltz, did you ever get to the bottom of this?
Electric Druid Synth and Pedal DIY website
