Just made a new Mini Control Panel
Page 1 of 1 [10 Posts]
blownauratone
PostPosted: Wed Nov 16, 2011 8:12 pm    Post subject: Just made a new Mini Control Panel
Subject description: a very basic Lunetta controller pack
I finally got a load of parts in, and jumped at the chance to make the thing I've been wanting to add to my tiny breadboard setup: A dedicated control panel.
Posted Image
In the setup are the following:
    8 1m Pots
    2 100k trimmers
    3 assorted light-depended resistors
    1 homebuilt vactrol
    1 momentary switch
..All brought out to header sockets, which are unfortunately very shoddy, falling apart already. Anyone have a favorite make/model of socket strips that aren't too spendy?
Please excuse the shady build- this is my first design on anything but breadboard Wink
Posted Image
Evidently took out some aggressions while cutting traces with the dremel.
Posted Image
Anyhow, it's working great, tons of fun. Today's 4-osc 40106 patch running through a 4077 for ring mod is super-fun with both pots and light sensors inline. Sweeping a signal through all kinds of FM-y madness by rolling back and forth in a chair is a pretty addictive thing. BWWWOAAAAAAAOOOHHHHHHHHHSSSHSSHHHHHHHHOOOOAAAHH
Thanks for all the great ideas, all. This machine is already making it into songs! I love it.
JingleJoe
PostPosted: Thu Nov 17, 2011 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
That looks very useful indeed, I'd be tempted to make something similar if I wasn't so poor Sad Send some of those pots my way Wink
-minus-
PostPosted: Fri Nov 18, 2011 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Use a 3MM drill bit to 'cut' the tracks of the stripboard. I hold the drill bit in a pin vice and just spin it around a few times (uncle krunkus method). You just need to cut the track. One of these:
 Filesize:  5.37 KB
 Viewed:  10641 Time(s)
tjookum
Audio files: 26
PostPosted: Sun Nov 20, 2011 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
very nice build, it's just like any other hobby, good tools are so important.
You might want to check this thread I made when I started out:
http://electro-music.com/forum/topic-42357.html
I used it to document my all perfboard and header lunetta build and I think it would really compliment your control board.
The lunetta link-o-rama is also a good place for further inspiration. And please keep posting your work, it's always nice to see how someone else tackles the same problems/challenges.
p.s.: where did you get those breadboardwires?
Hunter S. Thompson
movies
noise
garcho
PostPosted: Tue Nov 22, 2011 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice job! Inspiring tools everybody. Making prototyping as fast as possible makes inventing easier
"The life of a repo man is always intense."
blownauratone
PostPosted: Wed Nov 23, 2011 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks much for the encouragement, folks (and the tool/technique recommendation!) This definitely ended up being a useful 'lil thing! I made some breadboard pin-1/8th" cables and have been having LDR/vactrol fun with my little eurorack modular. Smile (not to mention creating chaotic cvs from lunetta output! Haha)
The breadboard wires were from an eBay seller- ill post a link once I get near an actual computer.
MickeyDelp
PostPosted: Fri Dec 02, 2011 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had the same idea! Much easier than trying to stick pots into the breadboard or having a bunch of them hanging off on wires.
Potentiometer Board
 Filesize:  42.08 KB
 Viewed:  362 Time(s)
MickeyDelp.com
Delptronics.com
Inventor
Audio files: 270
PostPosted: Mon Dec 05, 2011 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool idea, and handy too. Good to know that option is available. one could tidy it up into a nice box with a breadboard mounted in/on it as well to get even more solid construction for projects. Personally, however, I have found a selection of bourns thumbwheel pots to be an effective alternative ($1.24 each at digikey).
Les
blownauratone
PostPosted: Tue Dec 06, 2011 4:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
@inventor
Crazily enough, the nice little Alpha pots I used are just over a buck at Mouser. They work really nicely.
They come in various values and tapers. Here's the 1m linears I used:
http://www.mouser.com/ProductDetail/Alpha-Taiwan/RV09AF-40-20K-B1M/?qs=sGAEpiMZZMuarXojuOTsczn5Fi%2fS8UIapgiGEJXBgd4%3d
Inventor
Audio files: 270
PostPosted: Tue Dec 06, 2011 11:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a photo of the pots I use for breadboards. As you can see they are perfect for breadboard use unlike most (all?) others.
Les
Bourns Thumbwheel Pots, $1.24 ea for breadboards
 Filesize:  27.25 KB
 Viewed:  9819 Time(s)
