4 step sequencer unused pins to GND?
Page 1 of 1 [5 Posts]
acidblue
PostPosted: Thu Dec 31, 2009 1:50 pm    Post subject: 4 step sequencer unused pins to GND? Reply with quote  Mark this post and the followings unread
I'm trying to make a 4 step sequencer using the 'baby ten" as a guide.
I'm using a 555 for clock and a 4017.
I'm just going to use the first 4 pins 3, 2, 4 and 7 for the sequence.
I know for an 8 step you put pins 9 and 15 to each other.
But what about pins 10, 1, 5 and 6 , do I simply put the unused pins to ground?
ezekiel
PostPosted: Thu Dec 31, 2009 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
On CMOS chips, you ground unused *input* pins. Leave unused *output* pins unconnected.
So for your 4-step baby ten sequencer, use the 4017 first four outputs (pins 3, 2, 4, 7, in that order), then since you want the sequence to restart after that, you connect the fifth output (pin 10) to the reset input (pin 15).
acidblue
PostPosted: Thu Dec 31, 2009 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ahh, I see, that makes sense.
Thanks ezekiel.
One more thing, what if I want to add a reset button to the reset pin?
Do I simply wire in a switch in parallel to the reset pin and pin 10?
electri-fire
G2 patch files: 4
PostPosted: Thu Dec 31, 2009 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
acidblue wrote:
What if I want to add a reset button to the reset pin?
No, you connect the button (normally open momentary) between +V (pin 16) and Reset (pin 15).
acidblue
PostPosted: Thu Dec 31, 2009 8:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok great, thanks
